Members: 13,726 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 695 (19 members and 676 guests) Welcome to our newest member, idahoxiyosir |
15-07-20, 09:54 PM | #1 | |
Engine Oil on Tarmac
Folks,
I've had some engine oil get onto my drive. I've previously used Swarfega driveway cleaner and carb cleaner with success on a block paved driveway, but now it's on red tarmac and proving stubborn. So far I've only managed to spread the stain more. Any recommendations, please? |
16-07-20, 06:24 AM | #2 |
Oil on tarmac is not good. Any solvent will melt the tar and the oil also softens it.
Try cheap washing powder on wet tarmac and leave overnight before jet washing. There will be a stain I'm afraid you won't be able to remove without damaging the tarmac itself. |
16-07-20, 07:00 AM | #3 |
‘It’s true, I was going to suggest anything that’ll soak up as much oil as possible such as sharp sand, garage spill sand or even flour (don’t add a twist of salt, beaten egg & breadcrumbs otherwise you’re drive will look battered) to absorb as much as possible. But, if its been down this long, you’ll probably still end up with a mark.
16-07-20, 08:24 AM | #4 |
Cat litter is great to mop up fresh spills.
For old ones, it may be easier to dye the stain the same colour as the drive.
16-07-20, 09:52 AM | #5 |
The less popular, more cheeky suggestion might be to dye the rest of the drive to match.
Probably not so helpful.
16-07-20, 03:12 PM | #6 |
I think some of the old F1 races used to use cement to soak up the oil, I have used it on an old drive and it did work a bit and lighten the area almost to blend in. Didn't get it wet as I understand once wet in tarmac it will leave a light stain.
Just a thought |
18-07-20, 08:23 PM | #7 |
Tried more driveway cleaner then had a go with Bicarbonate of Soda, which seems to have lifted some more of the oil out and also little of the red dye within the tarmac
I'm resigned to there being a stain there now, but it looks a bit better than before, so I'm gonna call it quits on this battle. Thanks for all your tips chaps. |
19-07-20, 10:44 AM | #8 | |
21-07-20, 03:55 PM | #9 |
Get some of the dry sand you use to vibrate into concrete pavers after they are first laid. Heat it up in an old saucepan and dust it onto the oil to soak it up.
