Members: 14,973 | Total Threads: 40,057 | Total Posts: 470,834 Currently Active Users: 855 (28 members and 827 guests) Welcome to our newest member, ufuwuwovucinu |
29-01-13, 08:53 PM | #21 |
well that's an option for the front then, but I'd like to have the double bolt pattern so it's always an option to swap back to 4x108.
29-01-13, 09:03 PM | #22 |
Well that was the plan for the front, drilling the old hubs. but it gives me more options. also depends how much drilling costs. the passat hubs are £18 each.
The easiest way I can see having both stud patterns is to drill the front hubs and have adapters on the rear. |
20-02-13, 02:52 PM | #23 |
This might be a bit out of left field, but is there any chance that pattern replacement hubs on the rear are flat? Say, if Topran made some?
20-02-13, 04:45 PM | #24 |
Good call that. That might be the case to lower production costs.
20-02-13, 07:56 PM | #25 |
or presumably in that case the scallop areas could be filled in with weld to enable a new threaded hole to be positioned - leaving you with both the 108 and 100 pcd.
20-02-13, 08:40 PM | #26 |
If its any use my Typ81 80 is 4x100, and the hub flange/drive flanges are readily available, not sure about your bearing id if they would press in?? or the splines on the CV.
20-02-13, 09:01 PM | #27 |
I think the only (or the only one I have found) pattern part hub is made by febi, and its an exact recreation and has scalloped areas too.
20-02-13, 09:05 PM | #28 |
I've been trying to get hold of engineering firms to see what their professional opinion would be. But as of yet I haven't found one that would reply to my emails.
I guess persistence pays off though. |
20-02-13, 09:14 PM | #29 |
IIRC type 81 hubs are the same as a B2 passat, if both 4x100. And should both fit into type 85 front carriers and match the outer cv spline. Its just finding a replacement for the rears that is tricky.
07-03-13, 05:47 PM | #30 |
An Update
Just took the hubs to an engineering firm and they seem to think its possible to customise them.
I'll know the results in a week or so. |
