Members: 13,618 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 814 (19 members and 795 guests) Welcome to our newest member, icabejepz |
29-04-20, 08:31 AM | #21 |
It just pushes on.
Takes a bit of care to get it to sit at 0mph
29-04-20, 10:37 AM | #22 |
17-05-20, 01:18 PM | #23 |
Well, that's the binacle back in the car, and happy to say I've now got a working odometer 😁
Strangely, when I first got the binacle back in the car, the rev Counter needle was bouncing rhythmically up and down, between 0rpm and around 2-3,000rpm, and then fell to 0rpm and stayed there for 5mins or so before bouncing back into normal activity! Any insight into why this happened? Seems to be fine now. Also, as you will see, I've fitted a set of polished aluminium rings while I had the binacle to bits, and I'm really happy with the look. Certainly brightens up the look of the dash. Thanks again for the help everyone, especially Mikes2 👍 Sent from my WAS-LX1A using Tapatalk |
17-05-20, 04:33 PM | #24 |
Nice to see that's sorted. If you had the battery disconnected, the revs sometimes take a while to settle.
Hope the car's behaving.
27-05-20, 02:19 PM | #25 | |
Car is hardly being used at the moment Mike unfortunately. Probably less than 5 miles in the last 7 weeks or so due to the lockdown. Currently working on a couple of small surface rust areas at the moment, where each front mud flap had been trapping moisture over the years. Helps to keep me busy and out of mischief! |
