Members: 13,665 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 814 (22 members and 792 guests) Welcome to our newest member, fuwubuq |
05-05-18, 06:36 PM | #1 | |
C3 Brakes seizing -help!
Hi folks!
Thought I'd take my C3 out for a spin in this lovely weather, as it hadn't been out for a couple of weeks. I began to notice that it felt like something was holding it back. Then the brake pedal felt much firmer that I am used to. Just before I got home something seemed to go thud under the car somewhere, and all seemed back to normal. The front discs were steaming hot. Rear discs were very hot too, but nothing like the front. I don't think the problem has gone away. Can both front calipers seize at the same time? They are original. Any ideas please..... |
05-05-18, 06:53 PM | #2 |
No way all seize at the same time, the rears especially do little work compared to the fronts.
My guess would be a sticky master cylinder or brake linkage. You really would need to take it off to have a look at it, I’m assuming there’s no ABS or warning lights on the dash |
05-05-18, 07:15 PM | #3 |
As above I would think.....seized linkage or sticking master cylinder.
Does it have a vacuum servo or is it boosted via the PS pump? |
05-05-18, 08:33 PM | #4 |
No ABS.
Boosted by PAS pump. What is the brake linkage? Last edited by Ringmaster; 05-05-18 at 08:35 PM. |
06-05-18, 06:02 AM | #5 |
06-05-18, 06:26 PM | #6 |
Thanks chaps.....
From what you say it sounds like the master cylinder. Wouldn't be unexpected for a 31 year old part I suppose...... |
26-05-18, 05:55 PM | #7 |
Folks,
Finally got the C3 to my mechanic on Wednesday. He couldn't find anything wrong. It was behaving itself perfectly. Took it for a spin in the sun an hour ago and the problem returned. I could feel the car being held back,then occasionally surge forward as the brakes freed up, then felt it held back again, Front wheels boiling hot. Rear wheels not too warm, ok. This time the brake pedal is travelling about 4 inches more before the brakes engage. The front calipers are definitely the only ones affected and they remain engaged. I guess that would explain the extra distance the brake pedal is travelling now. I am going to get the master cylinder replaced regardless now. Before I do so, are there any further opinions from you all? |
26-05-18, 06:51 PM | #8 |
It’d be my shout still
26-05-18, 06:54 PM | #9 |
On my CQ the underbonnet temp gets pretty high I think.....and this is when my brakes would bind.
Does yours have a vacuum servo, if yes it would be easy enough to pull of the vacuum pipe when they're binding and see if they release ?.......if yes then servo not good. If you have vacuum servo! |
26-05-18, 08:32 PM | #10 |
+1 Keep the old master cylinder and open it up to see.
1992 80 quattro 20vt |
