Classic Audi Technical Mech/Tech Engine » Any Injector reconditioning firms? (200 Quattro Turbo 10v)
Old 08-01-18, 12:15 PM   #1
Modus
Default Any Injector reconditioning firms? (200 Quattro Turbo 10v)
The local firm doesn't have the adapters to test the injectors (or replacement seals). Has anyone found a firm that can test or service the injectors used in 1980s Audis?
Modus is offline   Reply With Quote
Old 08-01-18, 12:41 PM   #2
rangerovering
rangerovering's Avatar
I've used injectortune before for my Range Rover and the B4, happy enough with the service both times
http://www.injectortune.co.uk/
rangerovering is offline   Reply With Quote
Old 26-02-18, 01:57 PM   #3
larry49
If you mean CIS injectors...... as far as I know the CIS ones are not serviceable but can be checked for flow and spray pattern whilst connected to the fuel injection system on the car once removed from the head, the injector to head seals are not expensive so best to replace rather than test..........
larry49 is offline   Reply With Quote
Old 26-02-18, 07:04 PM   #4
andya
andya's Avatar
If it is CIS injectors, the various seals can be brought from vw heritage. Just go to the ekta parts website for part numbers for your car.
You can test the spray pattern, and if their crap, stick them in an ultrasonic cleaner (available from places like maplins) for a few hours.
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
