Classic Audi Technical Mech/Tech Engine » Ur quattro will not turn over with key
Old 02-01-18, 10:13 PM   #21
SwallownAmazon
SwallownAmazon's Avatar
I have got the big red Bentley book, with earlier '84ish and later '85/'86 diagrams.
Laid up for long periods, some of my cars insist on randomly weird electrical issues- simply pulling relays and fuses an reinserting is a common fix. Similar issues used to plague many of the systems I used to support in my old career. It's amazing how many problems can be fixed by unplugging and reinstalling connections. Even good old Boeings play up after a few days laid up unpowered, and re-racking bits often sorts it.
And yes, the connections behind the right headlight are a good call.
This stuff has been discussed at length on the Volvo Amazon forum I follow from time time. It's bl**dy expensive but seems to be the dog's for sorting out corrosion problems with electrical connectors causing voltage drops.
Old 02-01-18, 10:46 PM   #22
Colin Aitchison
Colin Aitchison's Avatar
Good result today but i can't help but wonder why the big clearout?
It may be time to move on from my current home and the storage space will be lost, I would like to keep every thing but that can't happen, I have many more bits and bobs to sell.
Old 02-01-18, 11:16 PM   #23
vorsprung durch technik
I suspected something was up, good luck with selling it all. Typo, you'll have no trouble selling the UR Quattro you just got started.
Old 03-01-18, 09:05 PM   #24
jimh
Hanuman, If you don't mind can please email me the correct wiring layouts for the Ur 1985 car, just when you have time no rush, thanks.
They're here:-
http://www.urquattro.info/
"1985 wiring diagrams in English"
Near the bottom of the main page.
Beware Bentley manuals are US spec cars.
jimh is offline   Reply With Quote
Old 03-01-18, 09:07 PM   #25
Colin Aitchison
You will get a kick out of this, had the car running for a good 20 minuets today, refilled radiator with coolant, stat opened up and ran Ok but above 1100rpm, so was messing about with that to get the rpm down and the 3mm allen key mixture screw and the car just died, so where do you start, turn the idle screw back up and un-turn the 3mm allen key mixture screw,
but the bugger won't fire up, make sure you have a spark, spark is ok, then the penny dropped, run out of fuel, well that should be an easy fix , maybe tomorrow.
Old 03-01-18, 09:10 PM   #26
Colin Aitchison
Originally Posted by jimh View Post
They're here:-
Many thanks, just what I was looking for.
Old 03-01-18, 10:13 PM   #27
sinbin5t
sinbin5t's Avatar
then the penny dropped, run out of fuel.
Been there
At least we admit it Colin
