Members: 13,914 | Total Threads: 40,056 | Total Posts: 470,827 Currently Active Users: 697 (18 members and 679 guests) Welcome to our newest member, osoyuzoxizobd |
19-10-10, 08:13 PM | #1 | |
Brake woes.
Evening all,
I was driving home from work tonight and the car (80 2.0e avant) was pulling big time to the left every time I braked. I assumed I had a seized caliper on the o\side so when I got home I jacked the car up and stripped the caliper off only to find that every thing moves freely. I set up a bit of wood to press the pedal for me while I cracked the bleed nipple. Nothing. I split the flexi from the brake pipe. Nothing. I followed the brake pipe back to the ABS unit and cracked the union there. Still nothing. I know I have pressure at the rest of the brake lines as I checked them while I was at it. This also lets me know I have power from the master cylinder. Does it sound like my ABS unit is duff ? Can they be fixed ? Thanks Michael |
19-10-10, 08:57 PM | #2 |
similar thing to this i think?
http://www.classic-audi.co.uk/forum/...ad.php?t=13481 anything can be fixed!! just depends how much time you have and how brave you are.. |
19-10-10, 09:09 PM | #3 |
B2 Brigade
had 2 audi 80s in with me since june both the same as ur own , i replaced the abs unit on both and it sorted the problem, id not seen this problem with the abs unit for about 4 yrs, but it does giv bother
www.northernretros.co.uk 1984 80 Sport 1970 hb viva 1983 Honda Odyssey 250 1981 Suzuki 450 GS 1980 t25 danbury |
19-10-10, 09:43 PM | #4 |
Thanks for the replies chaps
Missfire- In that link the guy would appear to have the exact same problem as myself. No pressure to the front drivers wheel. With the pipe disconnected from the ABS unit I can stand on the brake pedal with 2 feet giving all of my 11 and a half stone and not even a drip from the pipe. B2AUDI80- So it is my ABS unit thats faulty. Did you replace with new or used units when you fixed the cars you mentioned ? I don't think it will be a cheap part from Audi if buying new. |
19-10-10, 09:49 PM | #5 |
19-10-10, 09:54 PM | #6 | |
B2 Brigade
20-10-10, 04:35 PM | #7 |
Many thanks chaps
Fitted an ABS unit from the scrappies today. Result |
