Classic Audi Technical Technical Info » Compressor purchase
Old 21-02-21, 02:48 PM   #1
Ringmaster
Ringmaster's Avatar
Default Compressor purchase
Folks,
I'm thinking of treating myself to a small compressor, like the one below. Not had one before.
https://www.diy.com/departments/stan.../981016_BQ.prd
Do you think it would be powerful enough for small sandblasting jobs? 8 bar & 180L/min
Old 21-02-21, 03:16 PM   #2
tractor Dave
No, it's way too small.
tractor Dave is online now   Reply With Quote
Old 21-02-21, 10:12 PM   #3
What he said. You'd be lucky to be able to do up 4 wheel bolts with that in one go without waiting for the tank to refill..
You really need a 3hp motor and a minimum of 150 litre tank, preferably 200.
Sandblasting is seriously air hungry.
1988 90 quattro 2.6 TSR
Old 22-02-21, 01:12 PM   #4
droopsnoot
Yes, as everyone said, that's too small to be much use. And it's pricey - when 24L compressors turn up at Aldi they're a lot less than that.
I bought a compressor years ago for one specific job - to paint the engine bay on my Vauxhall. I was going to get a 24L one, but I got a 50L one instead which is a bit better. But then, Aldi started selling their cheap air tools and it turns out that 50L is nowhere near enough. I've got a polisher that won't turn when I'm using the harder foam pads, for example.
My mate advised me to get the biggest one I could, and I wish I had. I just wasn't intending to use it for the stuff that I do with it now I've got it.
droopsnoot is offline   Reply With Quote
Old 22-02-21, 07:01 PM   #5
Ringmaster
Ringmaster's Avatar
Thanks Chaps.
That is disappointing, the size is ideal, but good thing I asked.
I shall hang fire for a while and consider my options later...
Old 24-02-21, 09:36 AM   #6
4v6
The engine meister!
Before I managed to get a 200 litre tank and a decent compressor I had considered getting a hold of say 4 50 litre tanks and daisy chaining them with a pressure hose to get sufficient volumes and just use a cheap compressor to fill them.
Obviously the compressors wouldnt keep up with a spray gun or blasting gun but the initial volume of gas would at least be usable for a short time.
In the end I snagged a decent tank and compressor off ebay for 50 quid and used that to paint the whole car with, and even then the compressor couldnt really keep up.
Also, dont use PCL 6mm/ 1/4 inch fittings, use the euro couplers that have an 8mm bore as itll have less pressure drop.
