Members: 14,962 | Total Threads: 40,057 | Total Posts: 470,834 Currently Active Users: 952 (23 members and 929 guests) Welcome to our newest member, iloecmu |
13-12-18, 06:38 AM | #1 | |
Power steering hose 811422887K
This is the one between the reservoir and the pump. Mines leaking where it meets the reservoir. Think it’s had it!
Seems to be obsolete. Maybe I’ll have to get one made? Thanks in advance |
13-12-18, 02:09 PM | #2 |
Hi, That hose looks like the supply hose to the the pump and would be under low pressure I think, any good hydraulic hose specialist should be able to make one up to get you by.
13-12-18, 05:02 PM | #3 |
Thats what i had to do with my coupe, just got hydraulic hose from a supplier, you can use water hose as a temporary fix but it will degrade due to the oil.
10-03-19, 11:06 AM | #4 |
I got a new pipe for £20. They Reused the old banjo. What is the ID of the pipe? The guy said it was 5/8” based on the banjo. I thought it was 1/2” based on the diameter of the tank outlet. It wasnt loose going on, but it’s still Weeping at the tank. I’ve ordered a better clamp as I’m not sure a jubilee is right for the job.
