Members: 13,552 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 765 (21 members and 744 guests) Welcome to our newest member, ugveqiqiboq |
20-06-15, 06:57 AM | #1 | |
Electric to Manual Window Conversion on 1984 Coupe GT
Has anyone ever changed from electric to manually operated windows ? If so, I'd be extremely grateful for some pointers as my old green machine has one non-operational side window with the other intermittent. Replacement electric mechanisms are scarce so I was wondering how I could go about this modification.
20-06-15, 07:18 AM | #2 |
If you really want to it's as simple as swapping the window mechanisms over and drill a hole in the door card.
20-06-15, 12:57 PM | #3 |
Replacement mechanisms or replacement car? Even if we would presume that your mechanisms aren't repairable [which isn't true], how do you know that the problem isn't in wiring, for example, broken wires between doors and car?
09-03-17, 09:32 AM | #4 |
Electric Windows - back on the case .....
Back on the case now that she's operational again - electric windows: can anyone out there point me at a pair of re-conditioned control units OR a set of parts to convert them both to manual operation ? Obviously, I'd like to stick to electric if possible.
09-03-17, 10:58 AM | #5 |
What's wrong with your current one? Not working at all? Window cable broken? Plastic parts at the end of cables broken?
Window mechanisms are rather easy to work on, just needs some basic tools, angle grinder and electric drill. As long as those two plastic parts are fine, repair costs are pennies, if at all, if they are broken, then some mechanism has to be cannibalized for parts. Last year I made one power window mechanism for my mk2 golf from original manual + B3 audi window motor [basically the same thing as should be in golf] - just one, because I'm too lazy to finish my power window conversion |
12-03-17, 02:08 PM | #6 |
Passenger side is sluggish / intermittent - I try not to open it in case it doesn't close again.
Driver's side doesn't move at all - voltmeter reading dips with button depression so assuming presence of a motor winding but jammed mechanism. |
12-03-17, 02:31 PM | #7 |
Bad electrical connections can result in sufficient resistance in the connection that will result in an electrical load without the motor turning.
Damage caused by body shops (one bunch literally chopped through the cables in my quattro to replace a door, and used badly crimped bullet crimps.) Badly reconnected connectors- some multipin connectors have moisture seals which make pushing the connectors together difficult. Some have removed the seal, thus allowing moisture and corrosion on the pins. Simple Verdigris affecting the connections. Motor jammed? Again, moisture could affect the internals of the motor. It's far from unheard of, and may simply require opening the motor case, cleaning it all up/servicing. Cable spool/pulley damaged/cable jumped? The system works on a cable being wound around a loop. There is what looks like a plastic spider as part of the 'gearbox' attached to the motor. The spider can crack with age, causing the mechanism to bind when the motor applies tension. If you have evidence of an electrical load, then it really is worth looking at the mechanism more closely before abandoning it. A little pic-
I wish they would keep the damned Chinese away now that I can go home, so that I can enjoy Fish amok and a draught Angkor Last edited by Hanuman; 12-03-17 at 02:38 PM. |
12-03-17, 08:55 PM | #8 |
Yes, could simply be the mechanism.
For what it's worth, try spraying the mechanism with electrical contact cleaner solution. A good liberal saturation and leave to soak, then see how they perform. Worked for me. |
12-03-17, 09:46 PM | #9 | |
You have nothing to lose anyway; some stick will keep window in place just as well as broken mechanism... |
30-06-17, 08:45 AM | #10 |
Many thanks for all of the advice (more than one source) on this subject. I've got the regulators out and am building up the courage to start dismantling (week-end task). Wish me luck ......
