Members: 13,637 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 763 (17 members and 746 guests) Welcome to our newest member, ipotume |
15-12-16, 07:13 PM | #1 | |
B2 Sport (facelift) FUSE BOX
Needed asap. Not sure what is wrong with it but I've been told it needs a new one .
NLA of course. Car was made Jan 1985 and VIN is 81zFA095*** Part number of fuse box will follow... |
19-12-16, 07:57 PM | #2 |
Car also needs a warm up regulator, current version is supplying no help at all !
Thinking of getting mine rebuilt by KMI at Letchworth, unless you have a working one that you don't need? Picking car up Tuesday, from The Phirm, who appear to have found several unrelated issues - but all added together -resulted in non starting. |
19-12-16, 08:15 PM | #3 |
If it's this-
443941822A http://audi.7zap.com/en/rdw/audi+80+...941-120020/#16 Then it's an item with some common use 443, you can check the applicability (i) if you follow the link above. However. Before engaging in chasing I'll defined issues, I offer an anecdote. Very early in my ur- ownership, the dealership said I needed a new fuse box. They told me it was suffering corrosion internally, on the circuit board. 1) no corrosion 2) no circuit board- it's pretty robust I declined, and found the (very intermittent) fault after much testing. It was totally unrelated. What is the actual fault? The only problem I have seen is slack contacts, making a relay operate erratically. I've heard of melting, but only with circuits fused incorrectly, and overloaded.
