Members: 14,969 | Total Threads: 40,057 | Total Posts: 470,834 Currently Active Users: 974 (26 members and 948 guests) Welcome to our newest member, glucophage mastercard |
28-02-18, 09:11 AM | #1 | |
Heater control switch
I’ll be replacing the heater matrix at some point in the near future, currently the heater control switch only works on setting 3 & 4, very occasionally setting 2 will work.
Would this mean a replacement switch or is it possible I could fix it? |
28-02-18, 01:45 PM | #2 | |
If it's anything like the B2 setup, it could be the ballast resistor associated with the heater fan.
28-02-18, 03:20 PM | #3 |
Yes, you can fix it. It is caused by heater switch contacts being oxydized or burnt. Contacts themselves could be removed from switches, just need to undo two bolts, and then tiny strips of sandpaper should be used to clean the contacts.
01-03-18, 02:22 PM | #4 |
Got a similar problem with my C3. Replacing the ballast switch didn't solve it.
Airflow of setting 1 is hardly noticeable. 2 and 3 work as expected. Tried sandpapering the area behind the selection lever but it made no difference. Is there anywhere else I could sandpaper or check? |
01-03-18, 09:47 PM | #5 |
It's quite likely that the construction in question is similar to B3 one; contacts are behind heater switches, contact pack with six pin connector attached.
07-03-18, 12:12 PM | #6 |
Thanks for the replies guys. I picked up the matrix yesterday so when I have a moment I’ll get behind there and sort it out.
