Members: 14,917 | Total Threads: 40,057 | Total Posts: 470,834 Currently Active Users: 741 (21 members and 720 guests) Welcome to our newest member, adudeowisuyu |
04-02-17, 11:54 PM | #21 |
I would prefer to keep existing one, if it's working. I've read so much reports about crappy new thermostats that when I change one for a reason, I usually boil the new one first to make sure it works, lol.
05-02-17, 12:40 AM | #22 | |
Gmac: did you manage a run tonight after getting all the bits in and the coolant in? |
05-02-17, 07:08 AM | #23 |
Morning folks! Yep, you can tell I've got kids! Up before 7 o'clock on a Sunday!
Meant to update this thread yesterday.... I got out for an afternoon run to tesco, rock and roll! The car was started from cold and I can happily report that the temp got up to 93 degrees and stayed there for the whole drive. I stopped off at a friends on the way home and left the engine running, the temp creeped up and as soon as it got the above 95 degrees the fans kicked in!!! Pretty delighted with that! So it seems that my cooling system is now running as it should! Temp sitting on the gauge correctly, fans kicking in when the temp rises and the after run fans kicking in when the car is shut off and the temp is high! I suppose I could change out the sender for the gauge again with the old one to see if the old one is working, as it seems the thermostat change and the radiator temp sensor change finally sorted out the gauge. Who know! Haha. Oh and the thermostat came with a new o-ring and I used that. I also got a set of swan neck spanners through the post yesterday, ordered t 17:00 on Amazon prime and arrived with the post at lunchtime Saturday! Happy with that. SO I'll tweak the 10mm bolt on the top left of the flange covering the thermostat. So pretty good day yesterday, especially with Scotland's result against Ireland! |
05-02-17, 08:01 AM | #24 |
.......to the above.
05-02-17, 10:42 AM | #25 |
05-02-17, 11:06 AM | #26 |
Well done
