Members: 13,750 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 679 (20 members and 659 guests) Welcome to our newest member, ojunivef |
21-01-11, 05:39 PM | #11 | |
21-01-11, 08:00 PM | #12 |
Handbrake.
Seems it's a common complaint- find out how AFTER the fact, then glue it all together. The grip comes off first. there's a pin that retains it underneath, at the rear, push in, slide off (contrary to what it says in the service manual I have! Then, the main cover comes off. Although in this case, it didn't have to happen that way. Glue apparently is a good alternative to doing it properly. Anyway, all sorted. Next up- rear seta back rest. There is nothing in the manual that shows this. I'm suspecting I'll need to pull the liner out of the boot, to access some heretofore unmentioned retaining bolts/screws etc. However, if anyone has any insight (except Missfire, who's obviously just going to take advantage of someone with very little experience of broken t44s)
21-01-11, 08:03 PM | #13 | |
21-01-11, 08:05 PM | #14 |
It's not really using the manual as such. I just glance at the pretty pictures, for a clue, when the object in front of me appears to have been designed by a sadistic chinaman of the puzzlemaking guild.
Sadly. Audi have seen fit not to supply pretty pictures...
21-01-11, 08:20 PM | #15 |
making wooden things
get a haynes manual...
it says in there.. 2 screws at front bottom to release seat base cushion lift it up and out under there, 'straighten' 2 securing 'tabs' then with an assistant..one in the boot, one in the car.. push a screwdriver into a hole to release head rests, (while the assistant pulls upwards on the head rest), then do the same with the head rest retainer/slider/plastic things ...with an assistant..and get him/her/sadistic chinaman to pull them out also. then the seat back will be loose. |
21-01-11, 08:22 PM | #16 | |
or you
21-01-11, 08:23 PM | #17 |
There is an easier way to removing the interior Mark...
The Molotov Cocktail.
21-01-11, 08:27 PM | #18 |
edit!
head rests come out from inside the car...just little normal steel R clip things.. read it too fast |
21-01-11, 08:30 PM | #19 | |
*mainly a dayout in eastbourne. Not sure whether the locals are influencing your bad habits, or if this is your social re-engineering type response to the place
21-01-11, 08:32 PM | #20 | |
