Members: 13,672 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 796 (19 members and 777 guests) Welcome to our newest member, abapimujumca |
31-10-17, 07:40 PM | #1 | |
Car on SORN again until March
Well that was a quick 8 months
Have to say the old beast has behaved better this than it has for the last 10, though still had a few probs to solve but non major. So whats going on this year whilst its on SORN? 1. Usual rotor arm and cap as the high power coil chews them up in 5k miles 2. Upgrade the brakes and calipers. 3. Usual oil and filter change and clean and re-oil the K&N 4. Improve the chargecooler cooling with an extra fan (this will bring the number of fans this car has to 6 ) 5. Cure the oil leak from the rear diff (actually coming out the rubber boot for the diff lock) 6. Get the slightly buckled wheel repaired after hitting a flaming pothole last year in the dark. 7. 4 new tyres (these been on almost 5 years) as grip definitely not what it was (put my foot down in 2nd in the cold morning air yesterday and lost traction almost instantly) 8. Sort alternator issue, Only kicking out 12.5 to 13V, try a new regulator first but suspect one of the diodes internally goosed and cannot remember which Audi model I got this off lol 9. Electric aerial just started playing up again after its refurb last year so thats going to have to get a new internal relay this time. Needs to be spot on as off for a trip around Europe in it next year Green = completed
Coupe quattro 1986:-~450bhp + loooong list of mods! Audi A7 Bi-TDI SLine Black edition 2015 mapped to produce 600lb/ft torque! Audi S4 4.2 V8 cabriolet 2004:- Last edited by 20vcqdriver; 04-03-18 at 03:16 PM. |
29-12-17, 11:47 PM | #2 |
Well as I'm off this week, got a few jobs started and completed on Cq, The disi cap and rotor arm was done today and as usual took 2 hours of swearing and cut fingers.
The additional fan has been fitted to the charge cooler rad and the wiring uprated to cope. Brake upgrade started and so far looking simpler than expected... try and get some pics up with further info in next few days...
30-12-17, 01:05 AM | #3 |
Hi, I take it you have a 3B or ABY fitted to your coupe, the distributor cap and arm are a pig to do, as for the brakes what wheels do you have fitted to your coupe? I only have 15's fitted to my Gt coupe and 280mm front discs and G60 twin piston calipers just fit but the braking is out of this world compared to standard 256mm front disc and 54mm single piston calipers.
30-12-17, 09:08 AM | #4 |
Hopefully pics come out. had a few issues with photobucket recently:
New chargecooler fans installed. Have to wait and see if this improves hot weatherperformance. Discs are now288mm offearly A4 redrilled for the 4x 108pcd. Amazingly the carrier bolted straight on for the A4 calipers A4 calipers much bigger as is pad area: Yes have the 3B. In hindsight I should have moved the battery to under the back seat
Coupe quattro 1986:-~450bhp + loooong list of mods! Audi A7 Bi-TDI SLine Black edition 2015 mapped to produce 600lb/ft torque! Audi S4 4.2 V8 cabriolet 2004:- Last edited by 20vcqdriver; 21-01-18 at 05:52 PM. |
30-12-17, 09:42 AM | #5 |
I am also find it a little strange that the A4 brake carrier bolted straight on, do you know the fixing bolt centers on you hub ( 76mm or 94mm)? are you using 15" or 16" wheels with the A4 288mm front disc setup? I take it you are using the A4 caliper, single piston, what is the size of the piston? I moved the battery to boot near side, cut the battery tray off the engine bay fire wall and welded it to the boot floor and fitted hold down bracket as well, keep up the good work.
30-12-17, 09:48 AM | #6 |
This looks interesting, you'll have to keep me up to speed with this...
looking at your new discs, Im trying to figure out how you've been able to drill the 4x108 bolt pattern from a 5x112 disc?
30-12-17, 10:15 AM | #7 |
Very easy.
30-12-17, 10:24 AM | #8 |
Thanks Colin, most appreciated.
I was wondering, as the witness marks on Dave's disc were puzzling me.
01-01-18, 08:57 AM | #9 | |
01-01-18, 11:12 AM | #10 |
Oh Alternator seems to be sorted with change of regulator, now kicking out 13.75V. Slowly getting through list.
Going to Speak to AutoMark tomorrow in Middlesborough about final re-map once back on road, hope to get it upto 450bhp now brakes will soon be sorted
