Classic Audi Technical Mech/Tech Interior » Odometer still not working!
Old 27-03-17, 02:11 PM   #71
sinbin5t
sinbin5t's Avatar
will it ever work after i did it
Old 27-03-17, 07:30 PM   #72
Gmac
Gmac's Avatar
Don't follow??
Gmac is offline   Reply With Quote
Old 27-03-17, 07:35 PM   #73
sinbin5t
sinbin5t's Avatar
Originally Posted by Gmac View Post
Don't follow??
Well i did mine after you Gmac, remember ? needless to say it seem's not to be doing anything
Old 27-03-17, 08:08 PM   #74
Gmac
Gmac's Avatar
Ah! Bugger! What did you find when you took yours apart? Any knackered cogs?
Old 27-03-17, 08:14 PM   #75
sinbin5t
sinbin5t's Avatar
Yes a cog with a tooth missing, the little orange one, the tooth was sat on the printed circuit board I will have to take the clocks out again and see what's what
Old 27-03-17, 08:19 PM   #76
Gmac
Gmac's Avatar
Ok, so check the other cog that sits with the smallest orange one, it may be a bit worn too. Make sure everything is seated correctly when you put it back together. You could perhaps try what I did and have things apart and put it half back in to the dash and get power on it to see what's going on. It was only when I did this did I get the result that things were actually working and it seemed to be the reassemble that was knocking things out of sync, of sorts!
I put up a couple of YouTube links to my vids I took. Can you view them?
Old 27-03-17, 08:25 PM   #77
sinbin5t
sinbin5t's Avatar
I watched them, i will do what you did and try the things you did, if no luck i will come up to yours.
Old 27-03-17, 08:38 PM   #78
Gmac
Gmac's Avatar
More than happy to help out if needs be!
Old 27-03-17, 08:48 PM   #79
sinbin5t
sinbin5t's Avatar
Old 02-04-17, 08:20 PM   #80
sinbin5t
sinbin5t's Avatar
Clocks out again , decided to zero the trip and it did so when i pushed the lever, took the clocks apart, checked everything and can see no reason why the odometer doesn't work, so clocks back together again.
Will put them back in and see what happens.
