Members: 13,573 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 746 (11 members and 735 guests) Welcome to our newest member, iroyupeseoc |
03-08-17, 04:03 PM | #1 | |
door mirrors
hi can anyone shed light on how to remove the door mirrors on the 80 b4 saloon cheers
03-08-17, 04:10 PM | #2 |
You need to rotate them to reveal a pair of bolts in the base which secure them on the door.
Be careful with these. Only a 4mm allen bit and they're a soft material
04-08-17, 02:00 PM | #3 |
cheers mate give it a try later,will this take everything off as i will be respraying the car.
04-08-17, 02:05 PM | #4 | |
Get loads of WD40 sprayed down there before you try and leave to soak for a while, as mentioned the bolt heads can be like chocolate, if you round them out it's a drilling out job then. After these are taken out the whole mirror is removed. |
04-08-17, 03:47 PM | #5 |
yep 2 bolts stuck solid and rounding off, plenty of wd40 had been put on,and its the same bolt on either door so must be a problem with them,gonnae drill them out tonight after tea ,is there a wiring connection to be taken apart after all this and is it in the door skin or mirror cheers.
04-08-17, 03:53 PM | #6 | |
Take your time and you will be okay |
04-08-17, 03:56 PM | #7 |
thanks for that mate well appreciated cheers
04-08-17, 04:00 PM | #8 |
04-08-17, 06:48 PM | #9 |
yep 2 bolts jammed solid ,drilled out 1 was a right bugger had to drill halfway down the mirror shaft to release it, cleaned out the door bottom now sitting down with a can of magners, well you have to on a friday night if not going out cheers guys.
05-08-17, 11:58 AM | #10 |
