Members: 13,689 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 795 (21 members and 774 guests) Welcome to our newest member, amacdonea |
15-10-15, 12:51 PM | #1 | |
02 sensor voltage low
00525 (P0131) O2 sensor voltage low. Always had this code since I've owned the car. I recently changed the O2 (lambda) sensor while mucking about with the exhaust so was surprised for the fault code to come back after being erased. Any suggestions to what to try next? What readings should I be getting from the three wires that connect the sensor?
15-10-15, 03:24 PM | #2 |
Been a while since I've manually checked, but a feed, earth, and signal would sound about right. Signal should fluctuate between 0 and 1 volt.
15-10-15, 06:01 PM | #3 |
Id be looking for a connection issue especially since the sensors recent, probably a corroded or dirty contact on the multiplug etc.
15-10-15, 07:31 PM | #4 |
22-10-15, 07:25 AM | #5 |
Dodgy sensor! No continuous circuit on feed and earth and only reading 41 mv on signal. Replaced sensor with a more expensive NGK/NTK one and hey presto codes cleared. Thanks for the help chaps
