Members: 13,701 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 757 (21 members and 736 guests) Welcome to our newest member, otibopiwac |
10-01-18, 03:17 PM | #1 | |
Brian Rickets Tuned WN engine £250!!
Hello
1.9 5 pot 10V NA engine. However its been modified by Brian Rickets renowned engine tuner of days gone by. Great up-grade to a 1.9 or knackered 2.2 10V as this should be pumping out something like 140BHP+ Usual work includes head work, cam re-profile and fuel pressure increase. In excellent condition with painted block black still looking like new. £500 ono collected (Wiltshire) or could stick on a pallet £80. PM if required. Thanks Last edited by simons2; 08-02-18 at 12:52 PM. |
12-01-18, 09:14 AM | #2 |
Can you post a photo of the other side of the head including the inlet and exhaust ports please.
12-01-18, 09:44 AM | #3 |
Hi Colin, no worries I'll sort this morning. Cheers Simon
12-01-18, 11:30 AM | #4 |
There you go Colin. Regards Simon
12-01-18, 12:10 PM | #5 |
That answers my question, WN 1.9 is a carb engine, it looked like that was a fuel injection head in you first photos but the second set confirmed it, head looks ported and used, another daft question, do you know the size of the valves or are they just standard, The engine size 1.921 or 2.144 pistons are the same size, if you removed a spark plug and measured the stroke with a thin rod and turm the engine to confirm capacity 77.4mm = 1.921 and 86.6mm = 2.144, here I go again, re profiled cam and or any lift added, it will be a bucket and shim head.
12-01-18, 12:42 PM | #6 |
Don't know valve size but was assured it was an 'up-rated head' valves, cam, porting.
I'll go out again and measure the stroke. Do both capacities use the same size cam belt? |
12-01-18, 01:29 PM | #7 |
Don't Know if they are the same size but the 2.144cc is 120 teeth x 18mm
12-01-18, 02:08 PM | #8 |
OK belt is 120 teeth.
measured stroke best I could and got 89mm so must be 86.6 Code on head is 035 103 373G The injection inserts look just like the KV ones on another head I have!!?? Also its got a warm up regulator on it, did carb engines have that! Last edited by simons2; 12-01-18 at 02:17 PM. |
12-01-18, 05:33 PM | #9 |
No, carb engines have carb.
12-01-18, 05:34 PM | #10 |
Sorry, I meant choke.
