Members: 13,701 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 750 (20 members and 730 guests) Welcome to our newest member, otibopiwac |
31-07-15, 04:06 PM | #1 | |
B4 Coupe Pre-MOT work required
MOT has just gone on my 1996 B4 Coupe, I've not had the car long and its the first time I have had a mechanic look at it. I had it checked today to see what it might need for an MOT. There are a few items on the list i dont no where to start with so can someone advise please-
FRONT FOG LIGHT SWITCH- This does not light up as it should so will need a new switch. Will this just be an ebay job I guess? REAR WHEEL BEARINGS PLAY- Are these re-packable? If not where would I get them from? BRAKE COMPENSATOR- This is badly worn and not really doing alot anymore so looks like I will have to get another one. Any ideas where? All other items are thankfully just straight foward brake discs, CV boots etc so shouldnt be a problem. Thanks Scott |
31-07-15, 04:32 PM | #2 |
Bargain fog light switch for you on ebay Scott
http://www.ebay.co.uk/itm/AUDI-80-B4...item58b71a51ef The bearing is an easy job for a competent mechanic (which I am not!) Brake compensator will be a bit more difficult I believe but not the end of the world. Not cheap but vailable new from Euro car parts http://www.eurocarparts.com/other-brake-hydraulics and GSF http://www.gsfcarparts.com/parts/bra...ower-regulator Someone a lot more technically gifted than me will post advice I'm sure
1992 (K) Audi 80 2.0e 16v cyclamen pearl 1975 (N) VW 1303LS Karmann Cabriolet beryl green Audis Previously Owned 1973 (M) 80L 1.3 2-dr white 1979 (T) 80SE 1.6 met.bue 1983 (Y) 80CL 1.6 met.blue Last edited by cjp0349; 31-07-15 at 04:42 PM. |
31-07-15, 05:03 PM | #3 |
Thats excellent thanks- I've taken that switch!
31-07-15, 08:30 PM | #4 |
On front wheel drive cars the rear wheel bearings are adjustable, so you may be able to nip it up. If its dying I would just replace it, they are cheap so by the time you get it apart and clean it to grease I would just fit new.
Its straightforward to do, most difficult part is the calliper carrier bolts if they are seized/rounded out. I would have new calliper carrier bolts on hand as I would be prepared for the allen key to strip out.
05-08-15, 10:07 PM | #5 |
The brake regulator has a plastic ring attached to it. Does anyone no if you can buy the ring on its own? At the moment I seem to have bought a brand new 70 quid regulator just because I need the plastic ring!
