Members: 13,570 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 678 (8 members and 670 guests) Welcome to our newest member, etoveemurif |
22-09-18, 12:25 PM | #1 | |
Anyone fitted a WR Quattro air box in a KV?
Hi there,
I’ve heard of people swapping in WR air boxes into a KV but the triangular opening vane won’t match up to existing air feed from the wing, as it’s a lot bigger. Just wanted to know if anyone fitted one and if they modified the chute and what they went for or just left it without the feed? Thanks |
22-09-18, 12:31 PM | #2 | |
GT's with the plastic trunking had a habit of ingesting floodwater through it, so the Ur option is definately a wise one.
22-09-18, 01:03 PM | #3 | |
Ah brilliant! Did you notice much improvement in how it ran? I am going to give a go tomorrow, the air boxes are quite fiddly with the k jet on top! |
22-09-18, 01:12 PM | #4 |
Rather than noticing any power gain, I seem to recall the throttle response being quicker and the induction noise being louder. Neither a bad thing...
22-09-18, 06:11 PM | #5 |
I smoothed out some of the internals in the alloy box to improve the airflow, and reckon that I got a small gain.... However, it now has a tendency to ingest gravel if driving hard, every so often, I have to remove it from the back of the box, this is usually worst after driving on "tar and chip" repairs......
22-09-18, 06:35 PM | #6 |
Rather than all the trouble of fitting the Ur box Its just as effective to modify the bottom of the KV box and fit a K&N panel filter, All the gains without the pain Slacky now using my modified box on his and very happy with it as I'm sure he'll confirm
22-09-18, 08:37 PM | #7 |
20vcqdriver, how did you modify your box? Did you just drill it out? Did you modify any of the plastic feed pipe from the wing? I do have a K&N already in there, just trying to help it further breathe a bit better
22-09-18, 09:31 PM | #8 |
I confirm I’m very happy with it , slightly confused though , as you ‘modified’ the 90(KV) by drilling a few holes in & around the lower air box .., + the k & n .
The even more modified box I had off you is on the 80 sport , which sounds great & certainly makes it more responsive
22-09-18, 11:22 PM | #9 | ||
23-09-18, 02:53 PM | #10 |
