Members: 13,544 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 754 (18 members and 736 guests) Welcome to our newest member, utobiaz |
19-11-16, 03:21 PM | #11 |
Well will get them delivered for next sat as I use it to commute every weekend to and from airport ,, thanks all
19-11-16, 03:47 PM | #12 | |
If you do not have a 2T press or a special toolkit like this... then let the mechanic do it... I've also seen damaged hubs from one of the shells inside the bearing seizing up and then the hub needs replacement. Parts er quite cheap though. Oh, I'm in IT and in risk of wearing out my fingertips whilst ruining my cholesterol by sitting down and drinking coffee... Getting off of the chair and under the car is how I survive |
19-11-16, 06:54 PM | #13 | |
Does it whine at all speeds?
Mine would drone above 35mph before I replaced the wheel bearing. That was the only symptom - I could not tell anything was wrong in a static inspection. OEM replacements were about £50 I think. Consider if cheaper alternatives include a new circlip and driveshaft nut. Quote:
That's a tad optimistic. You could spend that long getting the driveshaft nut undone. If you go down the diy route this may be useful http://62.239.47.80/Audi/BearingShoc...gShockJob.html Last edited by ovalking; 19-11-16 at 06:58 PM. |
19-11-16, 07:03 PM | #14 | |
18-12-16, 09:33 PM | #15 |
Well , I got the front wheel bearing replaced and the whine has disappeared 👍👍👍
18-12-16, 09:47 PM | #16 |
19-12-16, 09:45 AM | #17 |
Wheel bearing can be a bit tricky to work out what side of the car the noise is coming from, but the rule of thumb is change the cheap parts first, do not go removing gear boxes if you are not positive that is the problem, buy the time you get to the bottom of the whine you will probably find a new noise in the car, that's just old cars.
19-12-16, 05:30 PM | #18 |
19-12-16, 06:11 PM | #19 |
Glad you're all sorted Ivor but I would have agreed with you if I'd seen this sooner, that's definitely a wheel bearing. Gearbox me arse, chancer more like!
19-12-16, 07:15 PM | #20 |
Hello Jack
I too am pleased to learn you got this sorted, it must be a relief to not worry about a big gearbox job now. I am in Hertfordshire, near your neck of the woods, and it would be very handy to know where you got this done...may I ask exactly which garage helped you? |
