Members: 13,512 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 659 (23 members and 636 guests) Welcome to our newest member, omonaciyuca |
20-09-17, 07:36 PM | #11 |
By adjusting the butterfly you're just adjusting the resting position of the butterfly valve, it's rare this needs adjusting, maybe the odd fine tuning.
What you need to work with is the mixture screw on the metering head (mentioned in point 1), this adjusts the fuel to air mixture at all engine revs, you need to get the car hooked up to an exhaust gas analyser and adjust it until it runs within acceptable limits, only then do you set your idle. This isn't something you can really guess, so to do this properly you need an analyser, especially if you're new to this. |
20-09-17, 07:46 PM | #12 | |
Sorry to butt in, is this what i need to do after putting a new fuel metering head on my 200 5T ? i have a running too rich problem too. |
20-09-17, 07:54 PM | #13 |
you may have already thought of this but, where it had the hole in the servo had the mixture been adjusted to compensate ? ie richer as it would have been running weak with the servo leaking.
20-09-17, 07:55 PM | #14 |
Almost certainly yes, the adjustment is completely individual to the specific engine at that point in time. So even if a metering unit is runs perfectly on one car, it will need adjustment when fitted to another, all sorts will affect it, specific air flow, compression, exhaust flow, everything you can think of. If it was brand new it won't be set up at all, just built and sent out, it will definitely need to be set up.
20-09-17, 08:06 PM | #15 | |
Yes it was brand new, now i have a clue to the over fueling problem i have. Many thanks for taking time to reply. |
20-09-17, 08:28 PM | #16 |
Hadn't thought of that.Thanks. Is the adjuster down a small diameter tube inbetween the fuel lines and the igloo?
20-09-17, 08:44 PM | #17 |
No Problem, always happy to help.
Correct, IIRC it's a 3mm very long allen key you need, this is a pretty sensitive piece of kit so be very careful not to press down on it too hard. Adjust slowly a half turn at a time, and count your turns in case you need to reverse it. As you're adjusting you need to let the engine settle for a couple of minutes before you take a reliable new reading. Something like the gunson's EGA would work for the home mechanic, not as accurate as a full size system but it will get you very close. http://www.gunson.co.uk/product/G4125 |
26-09-17, 07:59 AM | #18 |
Any updates on this, Matt? I noticed it passed it's MOT yesterday with no advisories.
26-09-17, 11:24 AM | #19 |
Went to Ilkley over the weekend to pick up a Gunsons gastester professional. Set the CO on sunday using it and its running sweet as a nut now. Took it in for the retest Monday afternoon and it passed with flying colours!
Re-taxed now so back on the road. Thanks for all the advice/help. |
26-09-17, 11:29 AM | #20 |
