Members: 13,698 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 781 (19 members and 762 guests) Welcome to our newest member, awulixecav |
07-02-15, 02:44 PM | #21 |
excellent , thanks !
07-02-15, 04:48 PM | #22 | |
Removing the loom is the smallest of all problems. I don't know about RHD, for LHD car there's choice - either to remove ABS hydraulic unit, or brake master cylinder with brake booster - I both times chose master cylinder and booster. I also removed fusebox to be able to get one hand inside. In any case the hardest part is to build loom good enough - involves powerful soldering iron [recently bought 100w soldering iron for some heavier work, because 30w is barely capable of 1,5 mm2, anything bigger is pain in the ass for it], connector disassembly to remove contacts to solder wires directly to them [what's the point of leaving small part of original wire?], good enough so the wires wouldn't get loose no matter what happens - and to wrap the result, again, as good as possible, afterwards. I chose modern mainstream way - with corrugated tubing, recycled in junkyard, wrapped in insulation tape. My first try was rather poor, with tendency for the tape to break at places where some connector joins the loom, now I made it better, both from that lesson and from lessons learn't while disassembling looms in junkyard. That's the troublesome way - the simple way is simply to remove headlight control unit and bridge four contacts. Headlight/rear light warning happens when either of control units passes some voltage to autocheck unit - empty socket obviously can't do that. Last edited by msh; 07-02-15 at 04:50 PM. |
07-02-15, 05:39 PM | #23 |
I know soldering terminals etc is best practice but I just crimped all mine , and it has lasted 20+ years .....
07-02-15, 07:28 PM | #24 |
This time it's about both power transmission efficiency and used contacts which weren't intended for wires that thick - so there's no other choice anyway.
07-02-15, 07:56 PM | #25 |
Im fed up too, i had a hair raising moment on the M1 couldnt see Jack for about 4 miles, and not even a reflection on a car in front!
23-02-15, 05:03 AM | #26 |
It turns out that they are even brighter then me normal brights
