Classic Audi Technical Mech/Tech Bodywork, glass & exterior fitments » Audi Coupe B2 strut brace
Old 05-11-17, 11:14 AM   #11
4v6
The engine meister!
Thats very much along the lines of the one I made for the old coupe GT i had many years ago, made a noticeable difference in front end stiffness to mine as I recall, i also fabbed one up for the rear struts as well went around the tank and couldnt be seen with the liner in place.
Good going Colin.
Old 05-11-17, 05:07 PM   #12
Colin Aitchison
Colin Aitchison's Avatar
Good going Colin.
I damaged the fuel tank return pipe last year and removed the fuel tank to fix it, when the tank was out I fitted a rear strut brace, was a tight fit between the tank and the rear seat panel.
Old 02-12-17, 08:13 PM   #13
Colin Aitchison
Well gents its been a while since my last post but due to other things happening in the garage and getting some work done to make money before Christmas this project was put on the back burner, the strut brace and turret mounts have been on the car in primer and today was my first chance to get some black paint on them, brace now is a round tube, the original plan with the 20mm square box section did fit but due to space limitations the head of the allen bolts at each side were touching the under side on the bonnet, the bonnet did close but when washing the car you could feel at the edge of the bonnet to wing gap that the bonnet was raised a little, the 18mm round tube with 2mm thick wall was my solution to this problem,
both flattened ends of the tube has a 4mm steel packer pushed into the end and then pressed flat in the bearing press ( no tooling marks ), if I just fattened the end of the tube the side of the tube may have split, I did weld the end of the tube to limit any possible ingress of water.
Old 02-12-17, 10:13 PM   #14
mackenzie50
mackenzie50's Avatar
Looking great - skilltastic!
mackenzie50 is offline   Reply With Quote
Old 03-12-17, 12:19 AM   #15
slacky
slacky's Avatar
90q-Cab.
2.3E-Ur-S6
Member 111
