Members: 13,686 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 790 (18 members and 772 guests) Welcome to our newest member, lisinopril india |
23-01-17, 09:45 AM | #1 | |
Shudders after braking??
Hi all,,Audi 100 c3 2.2 cd
Recently after driving for 5/6 miles I had to brake suddenly and when I started to build up speed from 40 onwards it started to shudder violenty,,it happened a week previous but wasn't as bad,,when I drove last time all was fine until I had to brake hard then it started???? Any suggestions please |
23-01-17, 11:16 AM | #2 |
Sound like the pads need dropping out and the calipers given a good wire brushing. If there is a lot of dust build up/rust the pads can struggle to move back from the disc after heavy braking.
23-01-17, 01:16 PM | #3 |
23-01-17, 01:19 PM | #4 |
My experience of warped discs is that they judder with any braking not just heavy.
23-01-17, 01:25 PM | #5 |
That's the thing it does judder lightly around 60mph but once brakes are applied it gets more severe and continues to judder as I then accelerate,,if parked for a little while it's ok again till I brake again??
23-01-17, 06:50 PM | #6 |
Just seen your post and two things cross my mind, you may have a slight warped discs that you may feel or not feel under normal braking and a semi-seized brake caliper piston or caliper sliders, from what you have said the juddering dose go away after a short time, you do need to strip down and service you brakes, you can do a simple test with a laser thermometer by driving the car have a go on the brakes to find the judder point, drive a little bit (200m) and stop, use the laser thermometer to find what brake has the highest temperature, that's the one that has a problem, you could use your fingers on the disc but I don't recommend it.
24-01-17, 07:27 AM | #7 |
Have you serviced the brakes recently?
A couple of years ago I re-assembled my front brakes after painting the front struts and under heavy braking would get a judder. When I stripped them down again I found a blob of paint (just a tiny bit) under the top hat of one of the discs which had kept the disc from sitting flat against the hub. Paint removed re-assembled and braking judder gone.
24-01-17, 07:48 AM | #8 | |
As Colin mentioned......use your infra-red-finger......you'll soon know!!...........or give it a run of a few miles making sure to use the brakes, then jack it up and compare how freely each wheel turns....or not. |
