Members: 13,735 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 833 (20 members and 813 guests) Welcome to our newest member, isehrbii |
23-11-16, 09:45 PM | #21 |
According to Euro car parts they are 39.2 high. Not sure what height I could get to fit
23-11-16, 09:53 PM | #22 |
23-11-16, 10:08 PM | #23 |
Just realised you're talking B2 coupe quattro and I was replying for Ur quattro, best place to go to for comparing audi disc sizes is 'brakes international' (http://www.brakesint.co.uk) Rochdale, their online shop gives all the sizes for audis, bit better than ECP or CP4L (same company) , by the way B3 discs for the saloons are 4 mm less than coupe ones (52 v 56) in the 276 size.
Hat size on B2 quattro is 41.7 thickness = 20mm, hat height on B3 saloon 20v is 52 thickness = 25 so disc inner face would be 10mm further in. A4 discs are hat height 46.2 thickness = 25 so again inner face 4.5mm further in and you have to redrill 3 holes and elongate one other as they are 5 stud. Have you researched ford,volvo or mazda that use PCD 4 x 108 ?, however you will have to machine as centre bore hole diameter is wrong. |
03-12-16, 08:51 AM | #24 |
Thanks everyone, lots to investigate over winter whlst the cq tucked up in its garage. let you know how i get on..
22-12-16, 08:54 PM | #25 |
Are you 4 or 5 stud?
might be interested in your setup.. how do/did you get 280 mm front and 256 rear? standard cq are 256mm front aren't they? Last edited by Gaz; 22-12-16 at 08:57 PM. |
23-12-16, 07:59 AM | #26 | |
Its much better than oe but compared to modern brakes they lag behind a lot , hence some uprated calipers to up the performance should be all I need. After all it only weighs around 1300kg
