Members: 13,636 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 768 (21 members and 747 guests) Welcome to our newest member, ekzofivi |
07-12-10, 09:42 PM | #11 |
Chris (Jogi730) has the best idea, Don't waste money now when you are going to fit 6 speed eventually anyway. And using the diesel box with our size tyres and wheels is the perfect solution as it makes the 1st 3 gears the same as a 6 speed S2 with 4th slightly taller and 5th and 6th usefully taller
The 6 speed CGR in mine reduces the revs in 6th but only to around 3400rpmat 80mph. Ideally I would like to be doing 3000rpm at 80 to help economy, but I'm happy at present. And how does anyone get 42mpg out of the KV? As the best I ever achieved was 38mpg on long motorway trip, was normally around 30mpg. Still better than the 15mpg I get now though when in lead foot mode which I admit is most of the time
07-12-10, 10:32 PM | #12 | |
I will wait until you,re up and running,then decide what to do.
07-12-10, 10:35 PM | #13 |
07-12-10, 10:38 PM | #14 | |
Sounds like too much hard work and cash.
07-12-10, 10:46 PM | #15 |
Much appreciated.
Thanks,for everyones input.(As I hadn,t a clue.)
I,m alittle wiser now,which makes me look a bit foolish. If you don,t ask,you don,t find out.
07-12-10, 11:11 PM | #16 |
jogi
I think I have a ur 3.89 diff lurking about somewhere if you decide to go down the ur g/b route
11-12-10, 12:30 AM | #17 | ||
Of course 1200 rpm under load that's not first or second gear is torturing. Even diesel is intended to be used in 1500-2500 rpm range. It's not pleasuring to change gears all the time, it's not healthy for the engine in long term, NA petrol engine doesn't have much torque below 2k [my NG develops 130 nm @ 1k, that KV should be even less], and actually I'm surprised to find that someone can even save some fuel by doing this - usually it's completely otherwise - because when engine is run at such low revs, usually lack of torque must be compensated with throttle - by running rich. My grandfather also believes that smaller engine = economy & lower revs = economy. He's driving 1988 1.3 carb golf - on road 70-80 kmph [but that car has 4 speed gearbox], in city 40-50 kmph, torturing that 1.3 sewing machine. Once I had to calculate average fuel consumption - after I had done it, I started to laugh. Why? Because he driving in that mushroom style was doing 7l/100 km [40 mpg]. While I got from my A80's 3A 8-9l/100 km [31-35 mpg]. From 45% bigger engine, in 30% heavier car, being driven in city 50-60 kmph, switching to forth @ 50 kmph [because worn out main bearings, so crank started to rattle @ 2k, otherwise I would switch to 4th gear as intended - @ 70 kmph], on road @ ~100 kmph, sometimes getting some adrenaline [in city] by turning full tacho with 2nd and 3d gears and sometimes when going home, testing, how fast my A80 is able to go. And enjoying the ride. And only thing my A80 had better than that golf was aerodynamics. So, is it worth to drive, thinking about pennies and getting, usually nothing, instead of driving, thinking about driving and enjoying it? I don't think so. Ok, I know that there's some people, who simply can't enjoy driving - I can see that from my mother, she can't. Quote:
13-12-10, 09:10 AM | #18 | |
I noticed this very low gearing on the diesel box of my 3.0TDi and which are frankly ridiculous, 5th and 6th are about right but the lower raitios are far too low geared and find I start in 2nd most of the time.
