Classic Audi Technical Mech/Tech Interior » Coupe, recovering door panels
Old 26-06-17, 08:35 PM   #31
sinbin5t
sinbin5t's Avatar
Originally Posted by Cynical26 View Post
I genuinely hated doing mine. Was ok removing and them refitting the scrim backing. The leather top finish was a pin in the ass!
Honestly, save half the hastle and buy the finished material with the foam backing attached.
Gluing the edges makes a right mess!
Did i miss that gee or are you talking about the doorcards ?
Old 26-06-17, 08:41 PM   #32
Cynical26
Cynical26's Avatar
Bruce, I'll be buying the one piece headlining cloth when I do that too. The door cards were enough to show me a couple of s spent now will get a better job in the end.
The finish with the glue is good but more than a bit messy.
Cynical26 is offline   Reply With Quote
Old 26-06-17, 09:05 PM   #33
sinbin5t
sinbin5t's Avatar
I am sure Adrian did that if you mean the cloth that is foam backed, he is going to put some photo's on to show us.
I can see me with glue and god knows what stuck to my hand till it wears off
David has some ideas in the pipeline too.
Old 26-06-17, 10:22 PM   #34
Davids
Ideas, yes, clue, no, well that's what the wife says sometimes.
Should be getting my headlining the end of the week, foam backed.
The crunch is the glue, 60 for 5 litres. However the lads that I am getting the stuff from are some of the best trimmers in the country, the work make you stand open mouthed, and if they only use this for hot applications then I'm going to use it, cause I don't want to do the headlining twice.
They also trim vintage aircraft, and you don't want something coming unstuck doing a loop the loop.
Once I get the stuff I will do a bit of a pic write up.
Cheers
David
Davids is online now   Reply With Quote
Old 27-06-17, 10:16 AM   #35
AdrianH
The glue I used was high-temp stuff in aerosol cans, and the covering was foam backed. Wasn't the nicest job I've ever done on a car but wasn't the most difficult either, just a bit messy.
AdrianH is offline   Reply With Quote
Old 27-06-17, 02:19 PM   #36
sinbin5t
sinbin5t's Avatar
When the time comes i will contact you Adrian, just need your photo's to encourage me now.
Old 12-08-17, 08:24 PM   #37
sinbin5t
sinbin5t's Avatar
The crunch is the glue, 60 for 5 litres. However the lads that I am getting the stuff from are some of the best trimmers in the country, the work make you stand open mouthed, and if they only use this for hot applications then I'm going to use it, cause I don't want to do the headlining twice.Once I get the stuff I will do a bit of a pic write up.
Cheers
David
Did you do the headlining David ? Unless i'm missing things you have been very quiet about the car, maybe you have been very busy.
Old 12-08-17, 11:26 PM   #38
Davids
No you haven't missed anything, I hang my head in shame, been flat out every night on the GT6 as I want to get it in colour before the summer ends. On hols now on the IOW visiting the outlaws, heaps of jobs to do, digging, building etc.
I have the headl lining and glue read to go alongside with a host of other bits, lower trims etc. Got a new set of rear calipers to change, rear wheel bearing has a little play, want to do the front bushes complete lot.
I am time short at the moment, Beaulieu auto jumble, the 3 days at Goodwood Revival, wedding aniversary party in Essex, another tough mudder to do, and a skydive to do, I need a holiday
Old 13-08-17, 12:16 PM   #39
sinbin5t
sinbin5t's Avatar
No worries, more urgent jobs come first, want piccies of it in paint though, the GT6 that is, and the tough mudder, and the skydive,and the walls
You do have your hands full !
Old 13-08-17, 11:17 PM   #40
vorsprung durch technik
Bruce, you'll need to Join Triumph torque forum, to see the GT6 as it currently stands. Looking utterly splendid in it's black epoxy primer!
And no Bruce, i'm not offering a sales pitch, i don't work for David or own his car.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
