Members: 13,588 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 1017 (17 members and 1000 guests) Welcome to our newest member, usuvekiyehay |
18-05-19, 08:44 PM | #11 |
Could it be the coolant after run pump you can hear?
I don't think any pump should be running on the abs when not activated. Try disconnecting the abs completely by removing the fuse or control box and see if that stops the noise. |
18-05-19, 08:58 PM | #12 | |
If I switch ABS off, I get no noise so it does seem to be the ABS. I suppose I could get it tested then figure this out after. |
18-05-19, 09:14 PM | #13 |
I've been searching the S2 forum for you and similar issues have been faulty bomb or the servo. A conversion to Vac brakes is recommended and ditch the bomb! Not sure if you have sufficient space though. Alex on the S2 forum (error404) does a very good kit and will advise if you decide to go that route.
18-05-19, 09:24 PM | #14 |
Or oil pressure switch at 23
https://audi.7zap.com/en/rdw/audi+qu...6/6/612-53005/ Also check you have good earth on the ABS pump (underneath on mine) |
18-05-19, 10:31 PM | #15 |
if it's only happening at really slow speeds as you are coming to a stop, it's the ABS modulator making the noise.
19-05-19, 08:31 AM | #16 |
I've been thinking more about this, in conjunction with comments and Thai site:
https://www.knowyourparts.com/techni...ator-problems/ I'm tending now towards sensor issues at low speeds making system think that a wheel is locked. The noise could be the valves opening and closing. EDIT(AS per Mike above-ABS modulator) At faster speeds the sensor outputs are more stable, so less likely to cause an issue. Of course it's difficult to drive around in the private roads here at 40mph to confirm this, so I'll have to take a look at the rear sender teeth and the connections before trying to remove and clean the sensors themselves (last option!) Off to Duxford now, so more in the week. Edit:I'll test the bomb first because the first check is simple. The interesting thing is the noise happens whether I'm braking or not, which (I think) only makes sense if the system is getting a bad signal from the sensors. Generally, the noise happens when braking or not, but certainly more often when braking. The noise doesn't seem to happen at higher (30mph) speeds, but does happen more often at lower speeds (less than 10), and also more often when braking-in particular braking to a stop. Last edited by BackintheFold; 20-05-19 at 09:30 AM. |
19-05-19, 10:38 AM | #17 |
I get a similar effect at low speed with the V8, when coming to a halt, and especially when turning.
10-09-19, 11:51 AM | #18 |
I've bought a £20 oscilloscope from eBay, so i can check the signals coming from each sensor-the re is NO WAY i'm prepared to remove any of them (and risk breaking them) until I know that that specific sensor is a problem!!
14-09-20, 09:00 AM | #19 |
Re-starting this thread.
My rear left sensor is giving a bad signal, so will check it out before too long-hopefully by end of September. The waveform showing on my oscilloscope is a square (ish) wave from three sensors, and a perfect sine wave from one. I'm aiming my sights at the sine wave, on the basis that I have read that the output should be square on this system. I may remove the driveshaft to clean the ring, or i may try to remove the sensor and clean the ring through the hole, then re-set the sensor. I don't want to disturb the tracking so will have to see if i can remove the driveshaft without disturbing it, then decide what to do.
2006 A3 (daily drive) 1987 MB ur Last edited by BackintheFold; 14-09-20 at 10:22 AM. |
07-11-20, 02:31 PM | #20 |
Finally got round to this.
Jacked car up, removed wheel. Sine wave output on oscilloscope Undid Allen bolt locking plate very easily. Tapped sensor with a hammer twice. Turned hub and now got a rubbing sound. Using fingers, grabbed back of sensor and tried pulling out and wiggling. Couldn’t see any movement but turning hub now resulted in No noise. Also getting a square wave! Hurray! Road test showed massive improvement, but on rare occasions on pulling up-even if not braking-I got a very brief pump type noise as before. If I was guessing, I’d say the system is looking for a certain pressure from the system and when it doesn’t get it it uses a mechanical pump to increase the pressure. I know that is not right, but maybe it’s an indication of what’s happenings In any event, I’m happy with it as it is. Now I need to replace the rear pads which are looking a bit low. Hopefully a standard part andnot a gazillion pounds!
