Members: 13,499 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 645 (24 members and 621 guests) Welcome to our newest member, safe online pharmacy |
11-06-17, 02:13 PM | #1 | |
Weird Plastic
Folks,
Not an Audi issue I'm afraid. My uncle's 2001 BMW 3 series has a black plastic console that runs from the gear selector leaver, backwards under the driver/passenger central arm rest. The plastic appears to be deteriorating on the surface and the plastic below appears pristine. If I wanted to spend ages gently scraping the surface I'm sure I could restore its appearance significantly. It looks like they tried to use a plastic that gave an impression of leather but ended up with something that is very soft, easily scratched and seems to be ageing quickly. Anyone had a similar experience or can suggest a way of dissolving/polishing the knackered surface plastic? |
11-06-17, 05:33 PM | #2 |
Ive seen a similar thing on other plastics, on a Kenwood home entertainment system.
The volume control was of a type of almost spongy plastic , at least it felt very slightly spongy until the surface went all sticky and yukky, breaking down, ive seen it on lots of other things also. Dont know what the solution is tho. |
11-06-17, 05:44 PM | #3 |
I tried to dissolve some of that, result ? well it turned to goo that wouldn't come off and then set rock hard overnight
Needless to say the said item had to go in the bin. |
30-06-17, 10:16 PM | #4 | |
(Knowledge from my background as a chemist in the surface coatings industry. ) |
01-07-17, 12:21 PM | #5 | |
01-07-17, 08:48 PM | #6 |
The same stuff was used on my A4 and my S8, and it goes the same way.
You can remove it with one of those green plastic scouring pads used for washing dinner plates (so I hear), soaked in IPA. It's messy, so ideally you want to remove the part from the car and wear gloves. You then have options of leaving it bare plastic if it looks ok, or vinyl wrapping it, or spraying it with plastidip. You have to remove all the old coating to wrap or plastidip it though as if the surface it not smooth, any imperfections will show through. If the part can be removed and is a suitable shape, I think matt black vinyl wrapping is probably the best option. I would only use plastidip if the part is too awkward a shape to use vinyl. |
