Members: 13,594 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 824 (18 members and 806 guests) Welcome to our newest member, iluzutezume |
01-08-10, 10:31 AM | #11 |
Youre not the folk whove had to pay for the bloody thing.Its easy to sit there and type up emoticons etc.
Ive said Im not working on this car any more.Phils offered help,but this is going to cost me money I dont have,not even £100.Its all gone into this car. If I break it I get more of the cash Ive borrowed from someone else paid back to them.Its not going to be given to someone on the cheap to get running.I want serious money back from some of these parts.Ive already sold my last car to Rod when 1000s had gone into it as I couldnt afford the last few hundred,Im not doing it with this car too. Shes breaking.I dont care how small the problem is.
Mercedes E220 Sportline Coupe |
02-08-10, 04:55 AM | #12 |
making wooden things
02-08-10, 04:58 AM | #13 | ||
[/quote]
from another thread.. Quote:
02-08-10, 05:05 AM | #14 | |
02-08-10, 08:48 AM | #15 |
Banned
For the record, I was called to another car with the same symptoms only two weeks ago. They'd fitted the check valve on the fuel pump the wrong way round. I had previously thought that impossible.
And - you have probably guessed - it was a DEALERSHIP! That problem was found by a flow test - the fuel pressure guage was quite misleading because the new pump could actually achieve full system pressure with closed injectors even pumping against a one-way valve - but if you jumpered the cold start valve into operation the pressure just vanished. A healthy system should flow 900ml or more in 30 seconds. Most actually manage 1.4 litres. |
02-08-10, 09:18 AM | #16 |
Banned
Hey up Groomy -
I would imagine the fault is very minor as it ran beautiful when you drove her from me, sounded and went great! If the fault occured only after you swapped the pump just check it's outputting and fitted (as Phil says) correctly. If new pump was better than old (knackered!!) one then it may have shagged the fuel filter or regulator. Just age related issues buddy. Dont forget it had a few minor electrical niggles before so check the fuel pump relay is behaving as expected. However, if you are breaking it why spend time and money getting her runing better - if the engine's coming out it won't matter a dot as it's highly unliekly that any buyer would be making use of your fuelling system too! It will only be a simple fix I'm sure. The first time I can get over would be in 2 weeks but we can get something arranged if req'd dude. |
02-08-10, 02:21 PM | #17 | ||
The original sin
Think your going to struggle to get serious money back from this car, no-one has them so doubt there's much of a market unfortunately. Even as a whole I doubt there's much in the car tbh.
80 tdi avant |
02-08-10, 09:11 PM | #18 |
Its proving extremely stressful this whole 200 malarkey.
I hear what youre saying there Pete.Cheers for the input. I know that a forum passionate about Classic Audis is not exactly going to be pro-breaking. With regards to putting the old fuel pump Ben told me was on its last legs.It at least ran though.Starting the flipping thing in the first place was hit and miss to say the least though.He mentioned something about the metering head.He stripped and rebuilt/reset it but it isnt brilliant.So,a KG metering head isnt exactly easy to come by.Does anyone know if a WR one would work?? The fuel pump I put in was the -040 Bosch fuel pump they list for my car. The one which I took out exceeded OEM spec,and was actually the std one for a Ferrari 400i. Does anyone know if the info about the -040 being for the 200 is duff??? Anyone else got a 200 and done a fuel pump more to the point??? See what Im up against???
02-08-10, 09:17 PM | #19 |
Classic Audi Pervert!
Similar to what Ben has said - worth checking the fuel relay is working correctly. It may be that you've fitted a new fuel pump but the relay is not up to the job (again as Ben said - age related). It could be that the relay was crap before, the new pump was put on and now it's causing an issue.
02-08-10, 09:32 PM | #20 |
Banned
