Members: 13,570 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 684 (8 members and 676 guests) Welcome to our newest member, etoveemurif |
27-04-16, 04:12 PM | #1 | |
Removing front shock tubes type 85 coupe
Hi guys use my car for work so am a bit worried about fitting my sports suspension, and realising I can't get the front fork tubes out of the struts. Having to keep the car off the road for a while till I sort it is not an option.
Are the strut caps that hold the front shockers in likely to be seized on or are they usually easy to get off? |
27-04-16, 04:31 PM | #2 |
Mine were really tight.
Lots of heat and they came undone eventually.... |
27-04-16, 04:41 PM | #3 |
sometimes, they can be a bitch, depending up how long they've been on, environment, state of the bellows. But with the right tools, you'll be fine. They should be tightened to about 150Nm, to give you an idea.
The hex size is 33mm, I think. There is a special tool that makes it easier (VW2069). Most places resort to stilsons, which just make things bad for later. If you have all the tools and bits to hand, it's about 1-1½ hrs each side, to drop the strut out, disassemble, reassemble, etc.
27-04-16, 05:01 PM | #4 |
Not sure if I have a long 33mm spanner but never need to much of an excuse to buy new tools defo a job for the weekend tho!
27-04-16, 05:28 PM | #5 |
It's not a spanner. It's an internal hex. You need something to fit in the hole, that fits over the damper rod. Hence the special tool.
I wish they would keep the damned Chinese away now that I can go home, so that I can enjoy Fish amok and a draught Angkor Last edited by Hanuman; 27-04-16 at 05:31 PM. |
27-04-16, 06:50 PM | #6 |
Hmm looks like it will be the monkey renches for me going to try and source some spare struts so I can do a strait swap. Dead easy finding parts for the b2
27-04-16, 09:51 PM | #7 |
Give em a good shock or 2 with a hammer and plenty of wd40, they come off easy enough
28-04-16, 12:54 PM | #8 |
28-04-16, 02:22 PM | #9 |
Aircraft engineer's essential tools-
Hammer* Condom* Either hit it, or FCUK it... * One size fits all, apparently
28-04-16, 03:33 PM | #10 |
Jeez...I wish I'd flown with you.....I'd have never stopped laughing....
