Members: 13,590 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 843 (17 members and 826 guests) Welcome to our newest member, dujpoclrepa |
13-05-20, 06:14 AM | #1 | |
OBD Measurement blocks for Audi 80/90/100 2.0E ABK engine
I have an 1993 Audi 80 with a 2.0E ABK engine and a Digifant II ECU that is currently not revving above about 3000RPM but showing no fault codes on the OBD reader. (Ross-Tech VCDS).
Does anyone have access to a map of the engine measurement blocks? Some of them are fairly self-explanatory such as RPM and a voltage that is clearly the battery but others are less obvious, for example several just labelled “Voltage” which hover around 0-1V and I presume are the sensors but it would really help to know what is what. Also, lots of the same or similar values seem to pop up multiple times in different places are they just duplicates, or is there some other significance to that? Thanks in advance for any help. |
16-05-20, 04:10 PM | #2 |
Thanks to Dana and the other great support people at Ross-Tech I now have the map.
Here it is in case anyone else finds it useful. ; ; VAG-COM Labeldatei ; ; Audi 100 (4A) ; ; Komponente: Motorelektronik (#01) - ABK (bis 06/1993) ; ; T/N: 039 906 022 ?? ; 000,0,Basic functions 000,1,Intake air temp,Setpoint: 15...70 (12...65 °C) 000,2,Supply voltage,Setpoint: 115...150 (10.8...14.0 V) 000,3,Coolant temp,Setpoint: 0...8 (85...115 °C) 000,4,Engine load,Setpoint: 35...65 (14...25 %) 000,5,Lambda sensor,voltage,Setpoint: 230...80 (0.1...1.1 V) 000,6,Lambda control,time counter,Setpoint: 0 000,7,Probe status,counter,Setpoint: 0...10 000,8,Throttle pot,voltage,Setpoint: 10...130 (0.2...2.6 V) 000,9,Injection time,Setpoint: 3...7 (1.5...3.5 ms) 000,10,Engine RPM,Setpoint: 211...186 (770...870 U/min) ; 001,0,Basic functions (Basic settings: Drosselklappe) 001,1,Coolant temperature,,Setpoint: 85..115 °C 001,2,Engine RPM,,Setpoint: 770...870 U/min 001,3,Lambda probe,voltage,Setpoint: 0.1...1.1 V 001,4,Injection time,,Setpoint: 1.5...3.5 ms ; 002,0,Basic functions 002,1,Coolant temp,,Setpoint: 85..115 °C 002,2,Engine RPM,,Setpoint: 770...870 U/min 002,3,Throttle angle,,Setpoint (Neutral): 0.0...2.0 <°\nSetpoint (Vollast): mind. 75 <° 002,4,Engine load,,Setpoint: 14...25 % ; 003,0,Basic functions 003,1,Coolant temp,,Setpoint: 85..115 °C 003,2,Engine RPM,,Setpoint: 770...870 U/min 003,3,Air intake,temp, 003,4,Supply,voltage,Setpoint: 10.8...14.0 V 004,0,Basic functions 004,1,Coolant temp,,Setpoint: 85..115 °C 004,2,Engine RPM,,Setpoint: 770...870 U/min 004,3,Ignition advance, 004,4,Engine load,,Setpoint: 14...25 % ; 005,0,Basic functions 005,1,Coolant temp,,Setpoint: 85..115 °C 005,2,Engine RPM,,Setpoint: 770...870 U/min 005,3,Throttle angle,,Setpoint (Neutral): 0.0...2.0 <°\nSetpoint (Vollast): mind. 75 <° 005,4,Supply voltage,,Setpoint: 10.8...14.0 V ; |
