Members: 13,716 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 690 (18 members and 672 guests) Welcome to our newest member, arudilamaqfi |
03-01-17, 06:23 PM | #1 | |
😞 battery light and abs on
After replacing my rear pads today I Went for a spin this eve and it was a very short 1😞
My abs light and battery light suddenly came on and i headed for home and just made it as lights got very dim and then the car would not re start??? (Not sure but may of heard something give just before the lights came on) |
03-01-17, 06:38 PM | #2 |
Have you checked to see if the alternator drive belt is still there??
03-01-17, 06:41 PM | #3 |
ABS System will disable when power supply falls below a certain threshold. So I'd suspect that as a symptom, rather than a fault, at this point.
Battery light on- loss of charge. Alternator belt?
03-01-17, 06:42 PM | #4 |
03-01-17, 06:47 PM | #5 |
You guys really need to start being a bit more open with model/engine specs. Different engines, different layouts, and all that.
However, assuming it's the 5 cylinder. Likely, to my knowledge. Front right. Bottom of the engine bay. Just behind the front bumper assembly. You might even see it through a grille, or feel it without getting too grubby
I wish they would keep the damned Chinese away now that I can go home, so that I can enjoy Fish amok and a draught Angkor Last edited by Hanuman; 03-01-17 at 06:50 PM. |
03-01-17, 06:55 PM | #6 | |
03-01-17, 07:02 PM | #7 |
It's the old 'confirmation bias' and (excuse any misquote) assumption being the mother of all screw ups.
I made the assumption based on having read a few threads, recently. But having 5 cars myself, each with their own idiosyncrasies even with 3 being the same 'model', it's easy to go off on a tangent.
03-01-17, 07:03 PM | #8 |
I think your belt will be lying in the road near to where the lights came on!
Sorry.......as real MSH has said........if 4-pot then RHS at top, I think. Hopefully just the belt eh? Page 135........ https://www.gates.com/~/media/files/...2016.pdf?la=en Last edited by John.; 03-01-17 at 07:10 PM. |
03-01-17, 07:10 PM | #9 |
03-01-17, 07:10 PM | #10 | |
I can't remember if the alternator belt is behind or in front of the hydraulic pump belt. I've seen the alternator adjuster mechanism rot and fail. It's more complex on the big chassis cars. It may be that the alternator is simply out of tension.
