Members: 13,512 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 649 (23 members and 626 guests) Welcome to our newest member, omonaciyuca |
19-06-10, 08:46 PM | #11 |
mk1 focus rs 4x108 and 324mm by 28mm. biggest i know of in 4x108
23-06-10, 07:36 PM | #12 |
What about the 4 stud Seat ibiza cupra discs
305mm, 4x100 with the 57.1 centre, redrill to 4x108? |
25-06-10, 12:58 PM | #13 | |
I've gone for 2.6 V6 280mm x 22mm discs with Wilwood 4 pots..
25-06-10, 01:00 PM | #14 |
Be interested in full details of this install, as need some better calipers but something that allows me to retain the 15" Ronal R8
25-06-10, 01:32 PM | #15 |
Indeed... Escort Cosworth too.
25-06-10, 03:25 PM | #16 | |
Part #'s Discs 8A0 615 301 E Calipers Wilwood 120-5093 Chris Eyre is a motorsport legend over on Club GTI. New brake lines will be needed as Wilwood use 1/8 NPT fitting, but when I ordered the calipers from Rally Design they knew the fittings I needed and supplied them. If you have the earlier front uprights you can use modified G60 Corrado discs which are the same size but with lower offset and the same calipers. Chris does mounts for the mk1 golf if you have caliper carriers with early 75mm centres.
16-07-10, 09:33 PM | #17 |
Is it not possible to change the hubs/brake system over from a mk2 golf to suit your purpose?
I know it's not 4 stud but I was hoping to swap the hubs and brakes from a mk3 16v? |
19-07-10, 07:24 AM | #18 |
The hubs are quite different I afraid.. certain golf brake calipers can be swapped over though..
19-07-10, 08:54 PM | #19 |
what's my best bet front and back while keeping it 4x100 and fitting under 15" wheels?
19-07-10, 09:25 PM | #20 |
fronts, golf g60 discs and calipers
rears, standard but new |
