Classic Audi Classifieds section Parts For Sale » New old stock parts lot.
Old 31-08-19, 05:28 PM   #1
The engine meister!
Default New old stock parts lot.
I have been going through the stuff ive amassed over the years playing with Audis and have come to the conclusion that I need to let it all go.
Theres just too much of it clogging up my garage and loft space and if im honest, the quattro will likely be next on the list, im just, well, tired now.
Heres a preliminary list with more to come over the next couple of days.
For reasons that elude me, most of its b3 and audi 100 stuff with an iddly biddy bit of ur and golf 1 in there also. The gasket sets I bought because much of Vw's 10 valve gasket parts are usable on 8v motors and vice versa, such as cam seals and stems seals so I was going to cannibalise them for ongoing jobs or as and when-hasnt really turned out like i wanted though.
The rest ill sort out in the next few days and add it to this posting.
Note its all german and italian stuff, like meyle, topran, metelli etc.
Still have some used stuff that can go in the mix too, keep watching in case theres something you need.
If youre interested in single items let me know, similarly if you want to take the lot make yourself known.
Updated list on 04.09.19.
These are NOS still in their packaging mostly, havent got prices on all parts just yet so many to check....all cheap like the budgie.
Photos of the parts.
026-198-049B PS overhaul kit X3.5 each
026-198-025A rocker gasket. Caddy 1983-1992 | Corrado 1989-1995 | Golf Cabrio 1979-1992 | Golf Mk1 1975-1983 | Golf Mk2 1984-1991 | Type 25 1980-1991 1.5-1.8 Petrol engines 1.6 Diesel engines 3
027-121-065C X5 water pipe. Golf Mk2 1984-1992 1.6 to 1.8 carburettor engines. 10 each
027-103-419 valve guides (TRW) X5 sets.(for 20v). 5 each
030-198-012D head gasket kit.
034-198-025C rocker cover gasket X1.5 each. 1 SOLD 1 left.
034-198-025 cork rocker gasket kit. 5 SOLD.
035-103-383J head gasket.
035-103-609 sump gasket.
035-133-837AB air filterbox top cover ur.15
035-198-025C OEM vw/Audi rubber rocker gasket.7
048-198-012 head gasket kit fits AAD/ABK.
050-103-383A head gasket.
058-198-012 head gasket kit.
111-905-865C ignition switch.7
171-402-303C front bump stops sus golf1. X2 10 Pair.
171-407-153D wishbone 924 1980-1988 | 944 1982-1985 | Golf Mk1 1975-1983 | Scirocco 1974-1981 20
171-419-804 tie rod complete with tr end (golf 1). Caddy 1983-1992 | Golf Cabrio 1979-1992 | Golf Mk1 1975-1983 | Scirocco 1974-1992 15
171-798-211 gear shift bush repair kit (x9) Caddy 1983-1992 | Golf Cabrio 1979-1992 | Golf Mk1 1975-1983 | Scirocco 1974-1989 5 each
171-798-105 clutch cable fitting kit X2. 3 each
171-498-625D bearing kit X2. Mk1 Golf Mk1 Golf Cabriolet Mk1 Jetta Mk1 Scirocco Mk2 Scirocco Caddy 12 each
171-711-574A selector rod X5. For all 1500-1800 4 speed models 3 each
171-711-574B selector rod X5. Mk1 5 speed, 1500-1800cc models, 5 speed 3 each
171-711-593D selector rod X5.diagonal shift rod 4 speed 3 each
171-819-809F heater valve X2 5 each
171-321-308 Inner rubber guide (fits clutch cable at gearbox). 3
171-419-812 tie rod end X2.10 each
171-711-593F selector rod X5. 3 each
171-419-832K.rack gaitors X2. 10 each
171-407-331F inner cv joint.X2.20 each
171-611-019E. brake master cylinder.30 (german)
171-419-883 steering rack mountings X2. 3 each
171-419-884 steering rack mountings X3 3 each
171-611-701GL front flexi X2. 7 each
171-407-643A hub nut self locking X6. 1. each
171-798-211 gear shift bush repair kit (x9) Caddy 1983-1992 | Golf Cabrio 1979-1992 | Golf Mk1 1975-1983 | Scirocco 1974-1989 4 each
171-498-625D bearing kit X2. Mk1 Golf Mk1 Golf Cabriolet Mk1 Jetta Mk1 Scirocco Mk2 Scirocco Caddy 15 each
171-609-721 brake cable X3. Handbrake cable, 2 required - To suit: - Mk1 Golf 75-75 to chassis >> 175 3025 867 - Mk1 Scirocco 74-75 to chassis >> 535 2001 030 10 each
171-711-574B selector rod X5. Mk1 5 speed, 1500-1800cc models, 5 speed 5 ea
179-609-721 brake cable X2. Caddy 1983-1992 7
192-721-555 accelerator cable X2 (NLA).golf2-carb,8/83 to 7/92, jetta 2 carb 8/83 rhd. 10 each
191-711-115 rubber gearshift gaitors X2. 5 each
1ho-711-115A g.shift gaitor leatherette. 10
211-261-325b X2 cotton reel mounts (gearshift mech).3
322-857-521 mirror glass.(paasat) 10
357-412-135 X2 dust cover. 5 each
447-698-151A brake pads with sensors. 20
4A0-698-451 brake pads rear. 10
431-498-099A CV joint kit.a100 20
431-412-175D front shock gaitors.X2. 10 each.
431-399-151D rubber mount X2. 7
431-698-471B X2 caliper overhaul kit.15
431-698-671 X2 caliper overhaul kit.15
431-959-455K Radiator cooling fan and motor assy.Ur.20
431-807-300D plastic push in fittings (for f+r apron fitting).1 each
431-611-701 brake flexi hose.10
443-407-615A wheel hub. Audi 100 man 8/74-12/87 3 spd auto 8/74-11/90 not cs or turbo petrol.(4 bolt)10
443-611-775B brake flexi.10
443-611-775A X3 brake flexi.10
443-698-151FK brake pads with sensor plugs. X1.25 1 SOLD 1 remaining.
443-419-812D tie rod end.RH 16mm.10
443-419-811C tie rod end.LH 16mm. 10
443-419-812C tie rod end RH 14mm X2.10
443-419-811C tie rod end LH 14mm. 10
443-412-377 strut top mounting X3. 7 each.
443-609-721K. brake cable. A100-drums-8/82 to 11/90. 10
443-609-721G brake cable.* 100 82 to 91 10
443-609-721H brake cable.* 100 82 to 91 10
443-615-361 brake discs 1 pair. 20
443-615-423X caliper.(xchange) rear 80 1/87 to 11/87.90 8/84 to 11/87.100 8/83 to 11/87.200 8/83 on. 200t 8/83 to 1/88.coupe to 7/88 girling calipers. 25
443-615-123 caliper. 100 4 cyl saloon 8.82 to 12/86. diesel and td saloon to 7/84 ate calipers. 20
433-611-775A flexi hose rear X4. 10 each (usual 18.50)
443-615-601 brake discs 1 pair.80 1/87 on. 90 8/84 on. 100 not cs, 8/82 to 12/87.coupe 8/84 on.cab 6/91 on.20
443-945-515 brake light switch.80/80q 8/82 on.90/90q 8/84 on.100 8/78 on.100q9/84 on.200/200t 10/79 on.200q 10/84 on. Coupe 8/82 on.Cq 12/84 on. Cabriolet 6/91on. Audi quattro 7/80 on (pedal fitting). 7
8A0-412-323BD strut top mounting. 15
8Ao-407-181 X4 wishbone bushes.10 all. SOLD.
811-199-419A. eng cradle mount bushes X3.2 each
811-609-721 brake cable. 80 8/78 to 3/85. coupe to 3/85 rear drums 1 piece cable.lh 15
811-609-722D. brake cable.80 8/78 to 12/86. 90 to 12/86.coupe to 7/88 rear drums and 2 single cables. rh.15
811-609-721H. brake cable.80 8.78 to 12/86.90 8/84 to 12/86. coupe to 7/88 with drums and 2 single cables.lh.15
811-609-721G. brake cable.90 8/84 to 12/86.coupe to 7/88 with rear discs.lh.15
811-919-059BA instrument panel printed circuit foil. 20 (
813-839-205B door handle, black. LH Rear 80 8/87 to 12/86,80q to 7/86, 90 8/84 to 12/86 90q to 3/87.10
855-399-151D gearbox mount.10
857-407-181 wishbone bush.5
857-199-415B front subframe bushes X2. 10 pair.
893-498-099E X2 CV joint Kit. 25 each.
893-609-722G brake cable. 80 with rear drums 1/87 to 7/91.lh. 15
893-609-721G brake cable. 80 with rear drums 1/87 to 7/91.rh. 15
894-941-115 lh light lens.80-80Q 1/87 to 7/91 10
894-941-116 rh light lens.80-80Q 1/87 to 7/91 10
893-407-148C wishbone (has all rubbers). 15
893-845-218 rear light cluster.lh. 10
893-407-365F ball joint. F 89-J-373 599>> - Audi 80/90/Avant(A80) 15
893-407-366F ball joint. F 89-J-373 599>> - Audi 80/90/Avant(A80) 15
2.0 metres of headlamp washer pipe (corect bore and o/d). 10
437-953-050 original rh ur indicator lens.SOLD
No11-903-3 core plugs 16mm X3.(5 cylinder oil gallery plugs).
No11-914-2 core plugs 24mm X2 (10 valve heads).
used/repro/miscellaneous.
857-121-131 X2 front ur bumpstops.polyurethane.15 pair
857-412-131A X2 rear ur bumpstops.polyurethane.15 pair
Ur hubnuts X4- 2 X pinch bolts for lower ball joints.1 each. SOLD
9gh-118-017-00 hella rubber boot for inner quadlight unit.3
9gh-116-966-00 hella rubber boot for outer quadlight unit.3
bonnet safety catch for b2- oem re-plated.5
stainless self fabricated version b2 safety catch.5
box used audi/vw plastic clips.5
AAB diesel block, crank and rods 2.4, stripped.50
2X 1.0 metres vacuum hose, 3.5 bore X7.5mm o/d, woven cover, black.3 SOLD.
85-945-697 coupe rear prismatic strips.
1 in good useable condition, 20 other poor but repairable (has loose bolts inside the unit).5.
Coupe/80 plastic airbox lower 5
857-857-755 seat belt stalk. X2 15 Pair.
811-837-709 inner door handle. 5.
1 Quadlight stainless bezel. 5.
321-201-285 fuel line shield. 5.
437-953-050 RH aftermarket indicator lens. Ur/200 5t.10.
811-877-433 sunroof bezel in beige. 5.
211-905-351 WR ignition amplifier module. 5.
034-903-143J alternator mounting bracket (20valve) 15.
Various relays audi/vw. 20 lot.
Takes ages this stuff!
Old 04-09-19, 04:59 PM   #2
The engine meister!
List updated.
Old 26-11-19, 09:33 AM   #3
BackintheFold
Wow that's an impressive list! Nothing i need right now of course...but i hear you may do replacement rear brake shields? part no. 857615611? If so, how much is that one please (rear left)
thanks!
BackintheFold is online now   Reply With Quote
Old 26-11-19, 09:35 AM   #4
BackintheFold
Darn where's edit when i need it...
might also need a rear shelf speaker. one of mine is intermittent, and I need to take it out and find if its reparable...
Old 01-12-19, 07:37 PM   #5
audizzz
Would these parts fit my son's 1987 B3 90 quattro?
If they do would be very interested in them
Thanks
audizzz is offline   Reply With Quote
Old 12-12-19, 06:18 PM   #6
edwells59
Default problems with identifying engine in audi 80 quattro
I recently purchased a 1990 audi 80 quattro saloon. original engine was 137bhp 20 valve injected. Just before the previous owner bought the car he was told that the engine was changed for a VW Golf. My problem now is that the engine casting code is almost unreadable - it may start with JS3. To add to the questions I was told he changed the head as well. So I think I maybe looking at an 8v 1984cc bottom end with god knows what strapped to the top. I ask these questions as you have been around the VAG block a while.
Any idea how I can identify properly the engine so that I can obtain spares. The head gasket just went so that is the main thing to be done. It has good oil pressure and no leaks but I have no idea what year the engine may have been from.
ed
edwells59 is offline   Reply With Quote
Old 12-12-19, 06:25 PM   #7
edwells59
The main reason for the contact is I see you have several head sets available. Whatever the donor vehicle its ended up being a 1984cc injected 20valve. I guess it may say on those gaskets what may fit. Interested in anything else Audi 80 quattro saloon. Cheers Ed
Old 13-12-19, 10:45 AM   #8
quattrodave
Are you sure on the engine ?, 20v even in 2 litre form was never 137BHP that sounds more like the 4 cylinder 16v engine (136BHP), no 80 in B3 form ever had a 5 cylinder engine.
Old 13-12-19, 12:14 PM   #9
edwells59
you are right its a 1984 16 valve original engine code was 6A but I notice the type is down as BA2 101KW. So its an odd one and the 16 valve 1984 16 valve was only in the car for a couple of years. Wikepedia isnt really helping me check out the old or the replacement engine at the moment.
Old 13-12-19, 02:18 PM   #10
Later 16v engines were ACE
1988 90 quattro 2.6
