Members: 13,794 | Total Threads: 40,056 | Total Posts: 470,827 Currently Active Users: 675 (18 members and 657 guests) Welcome to our newest member, abaicayekuyq |
04-06-20, 11:49 AM | #1 | |
Indicators not working audi coupe 20v q
Hi I have a 1991 audi 20v coupe quattro,
Indicators not working I have replaced stalk changed relay . Hazard warning working fine , fuses fine Can someone help please. |
04-06-20, 01:03 PM | #2 |
Have you changed the hazard switch side ?
I have an intermittent issue with one of mine where the indicators don't work the first time I use the car. Flicking the hazards on and off once fixes it and the indicators start working. If your hazards are working, it means the circuits are good so it's only the trigger side not working.
04-06-20, 01:07 PM | #3 |
Cheers for that I will try that
04-06-20, 01:13 PM | #4 |
Just tried that didn't work , I just cant work it out all other switches working but not the indicators , do the indicators and hazards have the same relay .
04-06-20, 02:41 PM | #5 |
yes they share a relay. It's under the steering wheel on a separate circuit from the main plate.
It sounds like you need to check wiring and the output from the switch.
04-06-20, 04:49 PM | #6 |
Sorted changed the hazard stalk working fine now , cheers for that.
