Members: 13,581 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 1139 (21 members and 1118 guests) Welcome to our newest member, oheculuxigep |
24-09-16, 08:05 PM | #1 | |
Supercharging a 7A
Does anyone know of anyone who has successfully supercharged a 7A engine? I turbo'd one a few year ago but the turbo lag was horrendous. I still have that turbo send fittings but unless I can hand a way of significantly reducing the turbo lag I won't be fitting it. This is why I'm interested to talk to someone who has successfully supercharged a 7A.
24-09-16, 08:38 PM | #2 |
Supercharged AAN in a 90q
http://www.s2forum.com/forum/showthread.php?t=38833 What turbo did you fit to a 7A before? A turbo 7A does not have to be laggy with the appropriate setup. There are also a couple of turbo and supercharged 20vs on S2forum.
04-10-16, 02:08 PM | #3 |
Hi Andy. Thanks for your reply. Sorry for not getting back to you. Great link by the way.
I turbo'd my last 7A using a turbo kit developed by 034 Motorsport specifically for the 7A. I was living in Dubai at the time and only came home a couple of weeks a year and this was a much easier option than trying to source a suitable engine, rebuilding and then fitting it. It didn't take long to fit but the problem is that it doesn't come on boost until 4000 rpm and this is not good at all. I tried to sort it but without success. The car it was in died a death a few years ago but I salvaged the turbo and fittings. I would like to fit it again but need to reduce the lag. It was OK on the track but on the road it was a pain. The turbo itself is a Garret hybrid developed by 034. The kit wasn't intercooled and was running a modest 7PSI boost. My plan was to intercool it but never managed to do so before it died. |
06-10-16, 01:03 PM | #4 |
it must have been a huge turbo or another issue for a 2.3 to not make boost below 4k?? fit a t25 to it for quick spool and about 250bhp.
06-10-16, 01:10 PM | #5 |
The turbo lag was because of the turbo being mismatched most likely, i once saw an mr2 with a similar mismatched turbo that would make 600 plus bhp at 8000 rpm mind you with the powerband only from 6k upwards, not what you want on a road going vehicle really, better to go a tad smaller than too large.
06-10-16, 06:31 PM | #6 |
Do you have any details on the turbo as I believe they used a couple of variations over the years?
Did you use the 034 7A software? A stock S2 KKK k24 7000 turbo can make 280bhp on a 2.2 with a very driveable powerband. 20vt is lower compression ratio, intercooled and the ECU has a MAP sensor. I think you would need the correct size turbo, and a standalone ECU to get the most out of the setup.
19-10-16, 09:43 PM | #7 |
Hi guys. Sorry for the delay in replying to comments. My thoughts are that the turbo is mismatched. As for details of the turbo all I know is that it is a garret hybrid of some description. The EU was sent to 034 for chipping and theoretically the whole thing should be just plug and play but that's being optimistic. I am looking to get the boost to come on much sooner than 4000 rpm, 2500 or 3000 would be acceptable In their blurb 034 say with this kit full boost is achieved by 3000. In my experience this is way off the mark.
20-10-16, 01:30 AM | #8 |
my thoughts are that its 034, i'm yet to see anything they do that is worth the money
20-10-16, 05:26 PM | #9 | |||
Current turbo 034 list is a
Smaller turbo would give you faster spool. I think the generic software is going to have to be very safe, so that is not going to be helping things. 7A ECU has no map sensor. 034 list it as 200 wheel hp / 250 crank hp. Intercooled, bigger injectors, more boost and appropriate software is 250 wheel, 315 crank. For reference a stock S2 k24 7000 turbo 2470 GGA Compressor, and 6.13 exhaust Turbine, gives 280bhp on an S2, nice spool for road use. Quote:
27-10-16, 10:15 PM | #10 |
Hi Andy. Many thanks indeed for that very comprehensive information. I've been in touch with 034 to find out what they think. They first of all want rolling road readout which I don't have and will be difficult to get without it being fitted right now. They seem to think it could the cam timing is out slightly. Possible as I had the head rebuilt and may have upset tgd timing on reassembly. What are your thoughts.
Cheers Steve |
