Classic Audi Technical Mech/Tech Suspension & Brakes » Brake bleeding order?
Old 17-12-16, 08:23 AM   #1
Gmac
Gmac's Avatar
Default Brake bleeding order?
Morning all!
Following on from my fluid question... Does anyone happen to know what order I should be be bleeding the brakes? (I could do with picking up a Haynes manual!)
TIA
Gmac is offline   Reply With Quote
Old 17-12-16, 09:46 AM   #2
cjp0349
Originally Posted by Gmac View Post
Morning all!
TIA
So could we all...But there isn't one!
In the Haynes manuals I have for the B1 and B2 and the early 90s Polo the sequence is right hand rear, left hand rear, rh front, lh front. Can't see any reason it shouldn't be the same for the B4
I think the theory is start with the wheel furthest from the reservoir and work to the closest
Old 17-12-16, 10:42 AM   #3
Ben
Bleed the master cylinder first and don't forget to do the clutch slave cylinder too.
Old 17-12-16, 11:36 AM   #4
I'm curious if it matters that much, even though they suggest a bleeding order.
If it's anything like other models, then front left and right are separate feeds from the master cylinder anyway. Looking at the parts catalog, 7zap, the rears also are separate feeds, then possibly through a pressure regulator/reducer to the rear.
Push fluid through, bleed the cylinder, then the lines, so that fresh fluid and any locked air ends up at the bleeds progressively further from the cylinder.
Just make sure the pressure reducer is working!
enjoying Fish amok and a draught Angkor
Old 17-12-16, 01:42 PM   #5
There is a Haynes manual
As you say theory is furthest wheel first etc.
I'd agree changing the fluid in the clutch line as also mentioned
Old 17-12-16, 03:02 PM   #6
cjp0349
As it's panto season John, I'll start it off
OH NO THERE ISN'T!!
Old 17-12-16, 04:50 PM   #7
OH NO THERE ISN'T!!
Ok B3.......close enough. For the likes of brakes the basics are the same.
On the subject of panto, where's Cinderella?
Old 18-12-16, 09:05 AM   #8
Gmac
Gmac's Avatar
Got the brakes bled!
Can't believe there's no b4 Haynes manual!!
