Members: 13,688 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 792 (20 members and 772 guests) Welcome to our newest member, equnpis |
06-12-10, 06:16 PM | #11 |
Sounds like air in the system as said previously. its a bit of a bugger to get to. from underneith i took the N/S driveshaft out and got my head right up to get a good look at it and then basically bled it blind qith a helper.
Not hard if you know what the slave looks like. A big peice of clear hose helps to see the bubbles if you dont have a bleed kit. |
06-12-10, 06:22 PM | #12 |
I'll assume this is going to be 100x easier without the engine in then, I'll just hang on until I remove it
06-12-10, 06:47 PM | #13 | |
Banned
However - the clutch plate will come out with the engine so you'll have to find some way of resisting the actuating rod's movement. It's a fairly powerful hydraulic system, so that could be tricky. |
06-12-10, 07:21 PM | #14 |
I hate hydraulics, it's never straightforward I think hydro systems may have overtaken wiring in the "things I hate about cars" awards
I guess I could just get a bit of plate and bolt it across the bell housing, should be alright? |
06-12-10, 10:43 PM | #15 |
Just stick a few bolts through the clutch and flywheel and your good to go. No more slipping clutch. Just have to start the car in gear, small price to pay.
07-12-10, 12:57 AM | #16 |
I drove my fiat 131 supermirafiori (?) 70 miles home without a clutch cable once!
That was fun. Sort of. That cylinder sounds *really* hard to get to... |
07-12-10, 03:09 AM | #17 | |
I probably got the best mpg ever on that occasion. |
07-12-10, 04:47 AM | #18 |
I drove one of my old Golf 16v's around without a clutch for out 3 months before the friction disc chewed itself to pieces
I'd rather not repeat the performance, it was a bit of a ballache on a daily basis |
07-12-10, 09:18 AM | #19 |
Banned
Thinking about it - you may well get away with bleeding the clutch with the clutch plate out because the piston is captive in the slave cylinder. The only thing it might do is throw the actuating rod at you. You'd have to be careful when putting the engine back, because pushing the actuating rod back into the cylinder might force enough fluid up to overflow the reservoir.
To be honest, if you've got that much access it would amount to criminal negligence not to replace the cylinder. |
07-12-10, 01:31 PM | #20 |
Is there a guide anywhere? I was only worried because it's MOT time tomorrow before I start gutting the bay!
