Members: 13,561 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 752 (22 members and 730 guests) Welcome to our newest member, uliviziubab |
14-09-08, 03:50 PM | #1 | |
jogi
01E into typ85
I have finally bitten the bullet and bought myself an 01E six speed gearbox.
I know it's not a diect replacement. Does anyone have the rundown of all the parts I need to acquire to complete this swap? Many thanks Chris __________________
1985 Audi 90 quattro 20v turbo with some tweaks |
14-09-08, 04:03 PM | #2 |
try the search,its been covered a couple of times......if your not a spanner man its not going to be easy!!i have done a couple of conversions now....check out s2forum
14-09-08, 04:10 PM | #3 |
jogi
Tried the search, but can't find anything.
Ideally do not want to go the 5 stud conversion Cheers Chris
14-09-08, 04:21 PM | #4 |
a 6speed linkage will be required,together with the gear lever(which will need modifying)unless you chop the raised section of the s2 tunnel and weld it in,the x member is different as the 6 speed mounting is in the wrong place(nearside only..offside should be same)ball joint sizes are different if you use 6 speed subframe.......you will be better off getting gearbox mounts made up to fit the origanal x member(or subframe)....clutch centre plate is different....only easy thing is it bolts to any 5 pot engine...good luck with the project...more info on quattro forum or s2 forum....i have been informed there will be an artcle about this conversion in audi driver mag
14-09-08, 04:29 PM | #5 |
jogi
Rob,
Thanks for the info. I may well go down the S2/ Audi coupe subframe route to help with roadholding issues (ie standars AARB's). I have changed my wishbones to cast ones from the standard pressed jobbies, so I am running S2 balljoints already. WHat about drive shafts and the prop shaft? ANy more innfo or links to this conversion would be most helpful and I will bviously keep my eye open for the article. Cheers Chris
14-09-08, 04:34 PM | #6 |
propshaft and front shafts should be direct fit....will try for some links..
Similar Threads | ||||
New tyres and/or wheels for my Typ85 CQ | S2 PTH | Wheels & Tyres | 6 | 24-10-15 09:24 PM |
01E 6 speed into typ85 | jogi730 | Transmission | 7 | 09-01-10 07:59 PM |
Typ85 4 pot hub nut size | pimpdriver | Transmission | 1 | 21-12-09 07:43 PM |
Typ85 Coupe | Puglife | Cars Wanted | 5 | 18-10-09 10:31 AM |
