Classic Audi Technical Mech/Tech Electrical problems » Audi 80 1994 immobiliser query
Old 04-08-16, 12:16 AM   #1
rangerovering
rangerovering's Avatar
Default Audi 80 1994 immobiliser query
Hi
My recent purchase seems to have its immobiliser in a twist. If I remove fuse 19 I can start the car, with it in place it fires up then cuts out after a second or so.
If I lock or unlock the car, fuse in place, the siren in the boot sounds for 3/4 seconds when locking and unlocking. Is this normal? Cos if so its bleeding annoying!
Any help much appreciated, tried to get a definitive answer via Google on this but there is limited pickings and not one gives hear symptoms.
I also only have one key, which has the single round push button for the torch but no obvious transponder chip. How does this work for disabling the immobiliser?
Thanks in advance!
Steve
rangerovering is offline   Reply With Quote
Old 04-08-16, 05:24 PM   #2
fourringsrus
fourringsrus's Avatar
You might get more response if you tell us which model, which year car etc
fourringsrus is offline   Reply With Quote
Old 04-08-16, 05:30 PM   #3
cjp0349
Look at the title of the thread fourringsrus!
Should have gone to spec savers mate
https://m.youtube.com/watch?v=t8GTHXTEvIc
Old 04-08-16, 06:16 PM   #4
I'd say you're missing a key. When it cuts out do you get the flashing light in the instrument cluster ?
fuse 19 is for central locking and anti-theft. you also shouldn't get a noise from the siren when locking or unlocking
It's normally just a single beep from a small horn in the boot
1993 S2 estate
Old 04-08-16, 07:20 PM   #5
rangerovering
Hi thanks for the replies.
Funny you say that mike he same thought occurred to me, I wonder if the previous owner has lost it and that's why it was sold as a non runner. I'll get the dash light flashing checked, it did do it before and the immobiliser would go off, siren sounding light flashing etc. It was a red triangle in the centre dash buttons though, next to the hazard switch I think. This model seems really basic, no on board computer etc.
Is a new key matched to the immobiliser easy to sort out? Presumably the unit will have to be sent away, I'm not sure where the code s are to program it.
Cheers
Old 04-08-16, 07:30 PM   #6
sinbin5t
sinbin5t's Avatar
Cheers
Don't know if your key is coded, but if it is they just transfer the code from one to the other without removing it from the original if that makes sense
If not, wonder how they do it, but am sure somebody on here will know
Old 04-08-16, 09:30 PM   #7
fourringsrus
Good point, well made,you are right, I went to Boots and got ripped off
Stuart
Old 05-08-16, 12:37 PM   #8
sinbin5t
sinbin5t's Avatar
Stuart
That's funny Stuart
Old 05-08-16, 12:55 PM   #9
It's a pretty basic immobiliser set up. usually a coiled wire around the ignition barrel so the key may be fairly straightforwards.
Not sure if you could get a non immobiliser version of the ecu which may bypass the requirement for another key
1993 S2 estate
Old 05-08-16, 08:30 PM   #10
rangerovering
Got a reply from the last owner, says he has only ever had this one key for the car. I just can't see where the chip is, unless it's fallen out when I opened the key....... That said it still didn't work before until the fuse was pulled.
New cap leads rotor arm and plugs on it tonight, runs better but still very lumpy. Unplugging injector 2 has zero effect and number 4 not much better. Thinking they may have got blocked, listening through a screwdriver they are all ticking........
