Members: 13,691 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 783 (19 members and 764 guests) Welcome to our newest member, adiyiduduke |
21-12-15, 04:15 PM | #11 |
I had noticed they had there own dizzy but the rest was new so thank you. Keep all info coming please ladies and gents.
Does anyone know was the GTI block a re-bored 7A block? |
21-12-15, 04:48 PM | #12 |
No a KV, but they did do a 20V 7A 2.5 conversion too. That was rated at 200bhp and similar torque but at higher revs than KV 2.5
21-12-15, 05:35 PM | #13 |
The KV with Schrick and various other modifications is a harsh old beast that needs driving hard, and 200bhp, whilst good, isn't a nose bleed in modern traffic. I would like to see a full fat KV TSR/GTI Engineering type motor with bang up to date electronic fuel control and ignition just to see exactly what could come from a n/a 10v 5pot
Quiet, they ain't... https://m.youtube.com/watch?v=q_hUS4wLmTE
1985 WR quattro, 1985 20vT RallyRep, 1993 MTM ABY S2 Avant. 2010 S3 Sportback. Last edited by Isimmo; 21-12-15 at 05:38 PM. |
21-12-15, 07:16 PM | #14 | ||
If you were to build a modern one a stand alone ECU could run EFI and coil on plug. It would be nice to ditch CIS. Imagine what it would sound like on throttle bodies! Simons do you want to stay CIS? Going to another CIS setup could give more fuel adjust ability and electronic ignition control, if you wanted to retain original looks. Aelred built a 2.5 10v with 202 bhp Quote:
21-12-15, 07:39 PM | #15 |
From the GTI website
The conversion comprises of: Chrome molybdenum steel crankshaft 94.5 mm stroke Alloy autothermic pistons Cylinder block bored and honed to 82.5 mm bore Gasflowed cylinder head 41mm inlet valves 35mm exhaust valves Special large cast iron valve seats Modified distributor Fitted oil cooler with thermostat Baffled sump Price £2500 (1985) Technical Data: 167 bhp at 5,500 rpm (std 136 bhp at 5,800rpm) 155 lbs/ft at 4,500 rpm (std 136 lbs/ft at 3,500 rpm) 0-60 mph 7.5 secs max. speed 130 mph From the TSR website 2.6l 5cyl short engine (2226cc exchange) Based on the 2226cc block, these units are fitted with a longer stroke crankshaft and bored to 82.5/83mm for a massive 2.6ltrs. To take advantage of this huge capacity we recommend the fitting of our Pack 'C' head in which form the engine will produce up to 185bhp. TSR PACK C 10V To release the full potential of the 5 cylinder engine, these heads are re-engineered to accept the same 40mm/35mm valve specification as used in the Pack C Golf heads. With similar attention given to porting and gasflowing these engines will easily give 170bhp when fitted with an appropriate camshaft. These power figures are similar to Quattro Turbo engines but without the turbo complications. Cam shaft Audi/VW 10v 2.2/2.3 ltr, Shrick, 276 degree, 11.5mm lift, Fast Road What was the load input for K star?
21-12-15, 08:17 PM | #16 |
I bet it would be close to 1 bhp per cc....
21-12-15, 09:13 PM | #17 |
jogi
Can I have one of those pleas? Could do away with the turbo!
21-12-15, 09:33 PM | #18 |
lol, yep, thank you, I've now spotted the mistake...
Maybe a bit optimistic... I was aiming at 2500cc making 250bhp... But I can't be asked to place a braincell in that general direction now....
21-12-15, 09:41 PM | #19 |
jogi
Damn, though you found a new formula!
I knew what you meant though
22-12-15, 08:54 AM | #20 |
Reading with great interest here as I would like to get some more low down torque out of the KV engine, but not al all cost
