Classic Audi Classifieds section Parts Wanted » Water Pump (Additional/run-on)
Old 08-11-19, 09:47 AM   #1
BackintheFold
Default Water Pump (Additional/run-on)
I found mine leaking last night, part number 034 965 561 C
I find similar on ebay at around 50, although they seem to be for A3s and modern cars.
Any suggestions as to suitability welcome! I think this is a part that should only be bought new, but any input on that welcomed.
Old 08-11-19, 10:12 AM   #2
Mikey-S
Mine let go recently, I didn't shop around because I needed the car back on the road, around 100 from TPS.
Mikey-S is offline   Reply With Quote
Old 08-11-19, 10:36 AM   #3
tractor Dave
Try Pete at Quattro corner. Might be expensive but it will fit properly.
tractor Dave is online now   Reply With Quote
Old 13-11-19, 05:02 PM   #4
spink
vw transporter T4s have a pump you can use,just needs a small bit trimming off the electrical plug and can be had for cheap
ford galaxys and sharans have a very similar one,ive not checked to see i they are useable or not though
Old 16-11-19, 03:40 PM   #5
BackintheFold
Bought Bosch. 48 from ATP
Perfect fit. Lost small bit of antifreeze.
Job done inside an hour start to finish.
