Classic Audi Community General Chat » 2019 Sorn work list
Old 24-10-19, 01:59 PM   #1
20vcqdriver
20vcqdriver's Avatar
Default 2019 Sorn work list
Well its almost another season done and time to put the Cq onto SORN. Not done many miles this year due to crappy weather but still got a list of jobs to sort over the 4 months its away avoiding the salty roads..:
1) Replace front strut top mounts including adding some support rings that will extend their life.
2) Replace rear strut top mounts for heavy duty versions (last changed in 1997)!
3) Oil and filter change. (despite having only done 2600miles this year).
4) sort annoying clunk/rattle from front offside wheel/suspension area.. (Not figured out what could cause it yet)
5) Remove and service the turbo and add upgraded hot side to eliminate the surge (Also help get power over 450bhp and on tests only added 200rpm to spool point).
6) Up to AutoMark for re-map..
7) New slave cylinder
Shorter list than normal but enough to keep me busy
Coupe quattro 1986:-~430bhp + loooong list of mods!
Audi A5 sportback 3.0TDI SLine quattro 2011, back box delete
Audi A4 2.5TDi Sport cabriolet (163bhp) 2004:- Remapped to 180bhp
Old 27-10-19, 12:08 AM   #2
20vcqdriver
New exhaust housing, up from surge producing 6cm2 to 10cm2
hope pic link works
Also upgrading the tracker I have fitted... Had this one for 5 years, recommend everyone with a classic gets one!
Old 27-10-19, 07:26 AM   #3
....who do you use when ordering turbo stuff?
Old 27-10-19, 09:54 AM   #4
20vcqdriver
Was guided to this company from the S2 forum, have used 034EFi before now for some bits but this is a straight swap for my present K26 hotside
https://www.turbosystems.info/produc...ousing-upgrade
Refurb of turbo is getting done by the company who put together the MD357 turbo in the first place ( https://www.turbodynamics.co.uk/ )
Old 27-10-19, 04:01 PM   #5
slacky
slacky's Avatar
Boooost!
90q-Cab.
2.3E-Ur-S6
-b2-80 Sport
Member 111
Old 06-11-19, 10:19 PM   #6
20vcqdriver
Pic of the strut top mount strengthening rings that have been receiving praise on the S2 Forum and will be fitting in the next two weeks.
Also got another job now as noticed the clutch reservoir was all but empty so looks like a new slave cylinder as no evidence of fluid on the drivers side floor and noticed the clutch mechanism has got very squeaky, so could mean a gearbox out job to remove fluid from inside the bell housing and re-grease mechanism and fit a new clutch release bearing which takes a hammering from the uprated clutch
Old 08-11-19, 10:01 PM   #7
Minty
Minty's Avatar
Always enjoy reading Dave, keep the updates coming
1984 GT5E Topaz Green
1983 GT5E Topaz Green - donor
Old 10-11-19, 08:56 PM   #8
20vcqdriver
Started the work this weekend, replaced passenger side strut top mount for the new version with its support rings. Made a special tool for the top nut many years ago and is one of many home made specialist tools to make maintenance on the cq a much easier and stress free affair:
Pics below of the difference between the old and new, new gap is 10mm+ less than before:
Old 17-11-19, 04:27 PM   #9
20vcqdriver
Well after 3 days on and off, managed to get turbo off ready for sending away for refurb and replacing the 6AR for the 10AR housing see below, Interested to see if it has the desired affect of eliminating surge..
Old 05-12-19, 06:48 PM   #10
20vcqdriver
Turbo now returned with new roller bearing core,billet compressor wheel and my 10cm exhaust housing. Just waiting for a couple of new hoses before refitting it
