Members: 13,691 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 784 (19 members and 765 guests) Welcome to our newest member, adiyiduduke |
24-05-20, 09:37 AM | #1 | |
Correct power steering fluid B2 90 Q
Advice please:
I am replacing the power steering pump with a ‘remanufactured replacement part’ and would like to know the correct power steering fluid to use. The only info I have is in the handbook which recommends ATF DEXRON for top up. There is a huge confusing choice out there can anyone help please? |
24-05-20, 10:32 AM | #2 |
Be careful as some b2`s use green mineral oil and some red hydraulic fluid. What colour is in there now?
Later Audi s all seem to use the mineral G00 stuff and you can't use red hydraulic or it eats the seals. Last edited by tractor Dave; 24-05-20 at 10:35 AM. |
24-05-20, 10:38 AM | #3 |
Existing is a dark brown colour now!
Should have added it’s a 1986 90Q with a kv engine code. |
24-05-20, 10:40 AM | #4 |
If the reservoir cap is green then it takes the G00 stuff, as far as I'm aware?.....but as above is it red or green that's in there?
24-05-20, 11:25 AM | #5 |
My 86 Ur has red in it and no green cap.
If the handbook is correct for your car I think you will be good with Dextron (red). |
24-05-20, 11:26 AM | #6 |
Like this Sent from my iPhone using Tapatalk |
24-05-20, 03:05 PM | #7 |
Thanks that helps, I know what to go for Now especially as my reservoir has no green cap and I suspect the brownish stuff in there was probably originally red!
24-05-20, 09:34 PM | #8 |
I'm possibly late to this.
If it was me and you've done a complete flush, I'd use the green fluid. They changed to using green in 86/87 and the part number didn't change. G00 2000 which has since changed to G00 4000 a few years ago. It's also called CHF 11 S or Pentosin
