Members: 13,628 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 802 (17 members and 785 guests) Welcome to our newest member, itnazeas |
09-12-11, 01:08 PM | #1 | |
80q addict
Typ85 accelerator pedal cover
According to ETKA, the pedal cover for the accelerator is listed as 171721647.
I managed to source one but it's just too small. Is this correct or do I perhaps have a LHD part number? Either way, the only way it looks like I'll get it to fit is to trim down the metal pedal plate. Any advice? Here's the ETKA diagram; Item 4) "pad for accelerator pedal" 171721647. And the cover itself; Hoyle |
09-12-11, 08:34 PM | #2 |
“Been raced and rallied”
Have you tried leaving it in some boiling water for a bit then try and fit it, might work..
Vorspurng durch Technik (see it does work) |
09-12-11, 09:29 PM | #3 |
Its been a while, but when I changed the rubbers on my quattro they were very tight and took a lot of persuasion to go on- after all you don't want them slipping off!
However, I've not seen your replacements and they could be the wrong ones?? |
09-12-11, 10:37 PM | #4 |
What Type 85 car is it,is it an q80?
09-12-11, 11:58 PM | #5 |
hey, didn't know they were suppose to be rubber? never had one on my 3 coupes. ???
10-12-11, 06:16 AM | #6 |
I thought only the clutch and brake pedal had covers? the last 3 type 85's I've had and the 2 I own now don't have them.
10-12-11, 07:07 AM | #7 |
10-12-11, 07:15 AM | #8 |
I should have,worded that better.
I was asking,because all 4 of my B2 q90's have never had rubber.Just plain old,ribbed metal.
10-12-11, 02:28 PM | #9 |
Might buy a cover for mine........ always best to rubber up......... sorry I'll get my coat and leave.
11-12-11, 04:13 PM | #10 |
80q addict
I usually soak them in hot water to soften them up prior to fitting, but the size is just way off, as in 15mm width and 20mm height.
I guess my options are leave it, or cut it down! |
