Members: 13,588 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 967 (17 members and 950 guests) Welcome to our newest member, usuvekiyehay |
25-06-21, 04:43 PM | #1 | |
No Spark
1984 UR Quattro Running great , next day ignition lights on turn key engine turns over will not fire up . Check for spark nothing , so out with the multi meter coil Ok good readings . Next up check timing marks , can't find flywheel ' O ' only a -- ( see pic ) do some UR's have a dash line instead of the O ? if not will carry on searching . any help would be appreciated .
26-06-21, 11:24 AM | #2 |
Mr Sixty Thousand!!
Any maverick spark on plug 1 ? Out of curious interest, was the car hot before it was last switched off?
http://www.oesems.co.uk/ |
26-06-21, 01:24 PM | #3 |
Assuming you've checked the primary and secondary windings when you say coil ok ?
Have you checked for 12v at + terminal ? Have you checked coil neg for switching ? Apart from checking the above my experience on UR ignition systems goes no further! |
26-06-21, 06:05 PM | #4 |
Timing sensor or timing pin
26-06-21, 08:20 PM | #5 |
No Spark
Thanks guy's for the replies .
1. Yes coil checked and OK 2. yes temp was normal when switch off after a 25 mile run before a M.O.T the next day ( had to cancel re none start ) 3. Will carry on looking for the fly wheel mark then on to the fly wheel pin etc. Thanks again Brecon P.S No maverick spark . |
27-06-21, 03:47 PM | #6 |
Mr Sixty Thousand!!
no maverick spark often indicates the ecu is not seeing the engine turning
