Members: 13,553 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 750 (20 members and 730 guests) Welcome to our newest member, ijunowekava |
03-06-10, 09:00 PM | #11 | ||
On the other hand, I've replaced about 8 master cylinders in various Audis over the last 20 years. |
04-06-10, 08:02 AM | #12 | |
Black Coupe Collector
Did the master on the CQ about 5 years ago, bought a slave a precaution just in case.... Anyway the slave went two days later, luckily overnight in the garage. So then I had the joy of getting it out. So will do the same here just in case the same occurs
95 UrS6 87 Coupe Quattro |
04-06-10, 04:02 PM | #13 |
Let me know how easy (or difficult) the slave is to replace - maybe I should do mine?
11-06-10, 11:23 AM | #14 | |
Now the slave cylinder, didn't take long to remove (one bolt from the transmission and the hardline), it appears someone had a go at the hardline before as the nut was a little rounded off , so I could not get a spanner on there easily in the space with the slave attached (the hardline was on there kin tight). So I removed the securing bolt out and took out the slave with the hardline attached and was able to remove the hardline with more space to get a decent access to the fitting. Much easier as the hardline turns into a flexi, so you can move the slave around to get better access. Now getting the new slave in there. There is a procedure for setting the slave cylinder in the inwards position using a 12mm cap fitting to seal off slave cylinder by creating a vacuum so you can fit the slave easily. Unfortunately that weekend my neighbour who has the bits to do this was away..... As the car was on the ground you have to go in from the top of the car, by leaning over the top of the engine. This means you have to pull the slave into the bell housing by strength and then get it lined up and get the bolt in which is quite hard to do. I could get the slave inside the bell housing but the bracket to support the hardline was fouling things up a bit and not letting the bolt go in there properly. So after messing about a bit with some lubrication still no success after many tries, I decided to remove the hardline support bracket and see what would happen and the slave went straight in and I could get the bolt in...... As I had limited time to ge the car back on the road I have taken the risk to run it temporarily in this way. Got the system bled, did it twice as the pedal did not come back the first time then on the second try it came back with a resaonable pedal which got even better after a quick test drive, so normal service resumed...! So at the moment its running without the hardline supporting bracket, which will get sorted out soon as I am not a fan of leaving things off. I'll also get a new fitting on the hardline as I am a bit fussy like that.
11-06-10, 11:33 AM | #15 |
Sorry about yesterday Luvy, Next time your about I shall try to be in
Nige
Horsepower is the force that determines at what speed you hit the wall, Torque is the force that determines how far you take the wall with you after you hit it. |
11-06-10, 11:41 AM | #16 |
No worries, I was actually about on Wednesday....
11-06-10, 12:14 PM | #17 |
Opps well that will teach me to turn the phone on
11-06-10, 12:19 PM | #18 |
No worries sausage...
